Monarch 10EE: Tooling?? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21
    May 2003
    4,626
    324
    On those diode brass ends, I cheated and used a Hardinge chucker, I drilled the 1/4" brazing rod deep, then parted them off like baloney. I made a little heat sink out of a piece of aluminum can, to keep from overheating the diode when soldering the ends on.
    Some of the diodes shown are the old style factory diodes, where the ends are crimped on to an insulated tube, with diode inside. If you take one apart you will see how it is made. The later factory diodes are enclosed, but the diode is soldered to the ends.
    The old style diodes can test good cold, but under power can lose connection at the crimped caps. Anyway, replacing them with fresh diodes is not expensive. One more thing on the diodes being enclosed, if there is a dead short in a circuit, the diode can explode like a firecracker spitting a bit of hot plastic, so wear eye protection if you have the cover of the module and powered up.
    I am working on a machine or two out in the weather, I will look in when I can.
  2. Likes Mac007 liked this post
  3. #22
    Jun 2009
    Kentucky USA
    106
    60
    11
    Well I was able to run the lathe and make the Brass Diode Ends today.
    Plan to solder them on the new diodes tomorrow, and install them in the module and run the lathe some more and see what symptoms persist.
  4. #23
    Virginia
    27,631
    7561
    8604
    Quote Originally Posted by Mac007 View Post
    Grab two cheap pair of "hemostats" AKA "Kelly Forceps", one straight, one curved.
    Look 'em up.
    Kelley Forceps - Google Search
    Any 'lectronics work they are heat sinks, third hand, truant parts grabber outta tight crevices - wotever yah need.
    Lay-down and weight with a hunk of drop, clamp, or vise-grab one loop, grip yer diodes by the leads, they stay put and divert heat of soldering, both.
  5. Likes Mac007 liked this post
  6. #24
    Jan 2017
    Washington
    265
    91
    I’m with Thermite on this one. Kellies are very useful. If you want a smaller version, they are called mosquitos. If you want stronger ones, they are called drivers.
  7. #25
    Virginia
    27,631
    7561
    8604
    Quote Originally Posted by medsar View Post
    Useful for-sure.
    About the ONLY thing I ain't (yet) used 'em for is their original intended purpose. Fast-clamping an artery full-shut so other work can proceed.
    Mind. I ain't no Hannibal Lecter, but still.. I HAVE met the odd free-range damfool now and then as was sore TEMPTING to have a go at OJT!
    You'd have to know machinists? Forever takin' s**t apart jest to prove we can put it back together again. Mostly, anyway.
    Unless we git distracted by sumthin' more interesting to take apart..
    Not sure we'd make very good medicalated chirurgeons, sech flighty priorities, but the other way' round might do as to more Old Iron "surviving the operation".
  8. #26
    Jun 2009
    Kentucky USA
    106
    60
    11
    I got all the diode ends made and diodes replaced today:
  9. #27
    Jul 2011
    Utah
    947
    2069
    376
    Donie, your PM box is full...
    (Sorry to distract from the topic)
  10. Likes Mac007 liked this post
  11. #28
    Jun 2009
    Kentucky USA
    106
    60
    11
    Quote Originally Posted by TheOldCar View Post
    TheOldCar,
    That’s Right, Donnie we can’t reach out to you cause your mailbox is full
  12. #29
    Oct 2016
    Florida
    45
    5
    Any chance you have any ends leftover? I am going to have to replace a few diodes on mine and likely just do all while I’m doing it. Have no way to make them since lathe is all apart and have no mill at the moment. Is there a source to buy these other than making yourself?
  13. #30
    Jun 2009
    Kentucky USA
    106
    60
    11
    Quote Originally Posted by dinotom View Post
    Hello, I sent you a PM
    I don’t know of a source for Modern diodes, with cylindrical ends installed. Some have soldered the modern replacement diodes’ leads directly to the module’s diode holder brackets. Others make the brass ends and solder them to the diode leads to make installation, later testing, and replacement easier.
    To make the Brass Ends you have to center drill the rod pieces & then solder onto the Diode leads. To do this, this was my process:
    I used CARDAS AUDIO high quality flux and CARDUS AUDIO Quad Solder which is a blend of: Silver, Copper, Tin & Lead and has a low melting point.
    I would pick up a brass end with forceps, hold over a bottle torch flame for 8-10 seconds then press one end into the flux which melted the flux and caused it to flow through the hole in the brass, from end to end. Re-Heat for 8 seconds, then generously feed solder into the hole at each end, Re-heat 8 more seconds and immediately slide onto diode lead and place in dish of acetone to quickly cool. I had about a 1/4 inch of acetone in the dish.
    I then cut off the excess Diode leads and cleaned the brass ends with some steel wool. Lastly I tested the assemblies with an Ohms multimeter.
    The modern Diodes are much more robust and higher quality than the originals.
