wildcatfan
- May 18, 2014
- Alabama
Was able to assist a friend in "rescuing" two Monarch CK lathes, one is a 12 inch and the other a 14 (i think), Both were destined for the scrap yard and were disconnected from power and "stored" in an open ended connex.
No wiring diagram or schematic on either of these 1941 model lathes, and we're trying to figure out the proper way to power them. Three phase power is available.
Neither lathe had power cables, and both motors had been disconnected from the switches.
Motor leads are intact and still have lead numbers on them. however cabling from switches was cut at back of lathe.
I'm by no stretch of the imagination an electrician, but all modern 3phase motors I work with have some sort of motor starter, even my 1941 Hendey has some type of mechanical relay/ motor starter, these have nothing. Or if they ever did the previous owner, scrapped them instead of storing them with teh lathes.
Can anyone provide the connection details or a wiring diagram on how to correctly connect power from line to lathe including having a functional fwd / rev switch? were motor starters used?
I've done web searches and looked at Vintage Machinery and Lathes UK, with no success.
Any assistance would be greatly appreciated.
