Monarch 16" Lathe SN 1-7154?
Likes Likes:  0
Results 1 to 6 of 6
    Jun 2007
    Amarillo, TX
    1,151
    11
    39
    Default Monarch 16" Lathe SN 1-7154?
    Hello, I looked at this Monarch 16" yesterday and wondered if this is the serial number? Also what model would this be? Thank you.
    Jul 2004
    Houston, TX USA
    28,741
    Nope, someones' asset number or the like.
    Its a plain bearing threaded spindle nose helical head likely from the twenties
    (the lift off covers over spindle bearings are for oiling these plain bearings)
    Actual serial, if there, is stamped into machined cast iron at right end on top in between two front ways
    Here is a somewhat related pub dated 1930 - thanks to John Legge and Greg Menke - somewhat related because it shows the TIMKENIZED head stock that replaced the plain spindle bearing version
    http://pounceatron.dreamhosters.com/...n-127-1930.pdf
    Jun 2007
    Amarillo, TX
    1,151
    11
    39
    I wouldn't have guessed the 1920's for its age, thank you.
    Jul 2004
    Houston, TX USA
    28,741
    Easy give aways for more modern is the cam loc spindle nose shown in this late thirties / early forties brochure
    Jun 2007
    Amarillo, TX
    1,151
    11
    39
    I see this is for sale close to me again, would this early of a lathe be a poor choice for a first time lathe purchase? Thank you.
    Jul 2004
    Houston, TX USA
    28,741
    Quote Originally Posted by Shawn Ghormley View Post
    Depends if you want an old slow plain spindle bearing lathe - made EXPRESSLY for HSS tools
    Note input pulley speed less than 400 in the photos - 345 in fact
    Also are you up for approximately zero support for "parts"? A similar vintage South Bend is very limited but way ahead in this respect..
    If it needs a widget - or a major gear, you will be the provider of that need - with whatever knowledge and skills are needed to MAKE same
    Thumbnail is the largest plain bearing Monarch I have ever seen - 42"
