I have a Monarch 613 16x30. I was drilling out some stock yesterday, and when I went to retract the quill it would suddenly only return about halfway. No difference in high/low gear, and it always seems to stop at the same point with no give. It's worked perfectly up till now.
I figured I'd try pulling the quill out so I could look in there to see whats going on, but I can't seem to get it quite all the way out. When it's got what I expect is an inch or so to go, its hitting some sort of stop before it comes out of the tailstock housing. On the far side of the tailstock is a round disc with two screws and a threaded hole in the center, and what looks like a pin halfway between the two screws. Based on a 612 parts diagram I found with a seemingly identical tailstock, it looks like that's a key in the side of the quill, and is presumably also what stops it from coming out, but I've been unable to figure out how to remove it. A jack screw in the center doesn't budge it, and I cant spin it either.
Anyone know the proper way to pull the quill out, or some other way of fixing the apparent jam on retraction?
