Monarch CY 16 Winter Project - Page 6
Page 6 of 8 FirstFirst ... 45678 LastLast
Results 101 to 120 of 156
  1. #101
    Oct 2018
    Kentucky
    168
    6
    35
    I have finished the TA rebuild, checking the results with setting zero on my new magnifying lens and quantifying wear. I find once I set to zero, I have 0.0006" of wear in the trough surface in the center. I'm calling that good. Doubtful I will ever taper something that long.
    Center on the indicator window is truly center so I'll add a red line on the lens, and call that good. It will only be a reference since any taper adjustment will be indicated in...
    Next, the apron...
  2. #102
    Dec 2016
    New York
    507
    7
    190
    Quote Originally Posted by WillWilly View Post
    I'll probably have to make one.
    I can send detailed dimensions on my TA bracket if you need them
  3. #103
    Oct 2018
    Kentucky
    168
    6
    35
    Quote Originally Posted by marka12161 View Post
    That would be perfect. Thank you. Yes.
    Im repairing the rod, attaching what is left of the mount.
  4. #104
    Dec 2016
    New York
    507
    7
    190
    Will do. Give me a day or two. When you get a chance, please check your PMs.
  5. #105
    Oct 2018
    Kentucky
    168
    6
    35
    Thank you very much.
  6. #106
    Oct 2018
    Kentucky
    168
    6
    35
    Zero!
    Calling that good.
  7. #107
    Oct 2018
    Kentucky
    168
    6
    35
    Permitex steel seal and weld. This was mainly for the back cover latch.
    Not my favorite solution but I don't want to put heat to this.
  8. #108
    Dec 2016
    New York
    507
    7
    190
    looks good from my house
  9. #109
    Oct 2018
    Kentucky
    168
    6
    35
    So some not so good news. The cross slide tapered gib is beyond the maximum adjustment, Very interesting factory maintenance crew fix...
    I assembled the gib to the position I found it. Not having ever taken a cross slide apart, I made note of how it came apart, including an interesting addition.
    Someone added a "tab washer"?? To push the gib past the maximum adjustment.
    The small end. The gib bolt was bent.
    So from some lengthy research confirmed my first thoughts of shimming the gib.
    From my measurements, i would need 0.020" of shim. I happened to have SS shim stock from end play on the headstock bearing caps.
    I made two shims which gets me to 0.018".
    Now there are definate opinions on shims or machining a new gib and scraping it in. Plenty of posts on how to secure the shims, what shim material to use, are we shimming or padding, what is the thickness of Loctite, you need to scrape after shimming, only real men replace gibs... on and on...
    Quite the saga, full of great reading but I will leave it up to you if you want to dive into the gib shimming pool.
    As much as I would like to go down the "remachine the entire apron" path, I'm going to go with the frugal fix and if I just can't live with myself, I'll revisit.
    And the last bit of bad news, the wiper cover is broke...
  10. #110
    Oct 2018
    Kentucky
    168
    6
    35
    The sixth picture and more than 10 charactors.
  11. #111
    Mar 2011
    Geneva Illinois USA
    6,235
    2686
    2416
    As far as the wiper cover, just weld or braze it and go one with life. The gib will function much better if it scraped in as well as the rest of the bearing surfaces.
    Tom
  12. Likes WillWilly liked this post
  13. #112
    Virginia
    27,791
    7561
    8635
    The sixth picture (.... was already SEVENTEEN, given one-space at a go counts, too)
    Dunno how or WHY it bustid, but I'd just lay a strip of steel acrost it, line it up proper. Drill, countersink both sides, and soft-Iron rivet it flushed.
    All it has to do is function. Not pose for movin' pitcher shows with pretty ladies.
  14. Likes WillWilly liked this post
  15. #113
    Oct 2018
    Kentucky
    168
    6
    35
    I like that idea. Im afraid with my Lincoln Mig 125 with argon I could just make a mess of it. Thanks
  16. #114
    Virginia
    27,791
    7561
    8635
    Oddly, 90% of the Arc i struck with my old Grainger/Dayton AC stick - about as poor a welder as ever was that could still join metal, actually - was on 0.042" wall square tubing and even had to LOOK nice. And did. But it were a pain in the anatomy to make 'em so, beans and second-rate bacon budget days.
    Worse? I credit an also too-damned-cheap mask and filter lens as a contributor to eventual sore blinding cataracts.
    Having had those fixed with bionic eyes, 20/15 near-as-dammit perfect L/R no need of glasses near or far vision?
    I gave the alleged welder away... to the guy next door's Bro. In Law!
    Any more welding I have needed since? I just HIRE done, and from folks who were always seriously BETTER welders than I ever was or cared about.
    Rivets OTOH? Those I'm BITCHIN' good at, "Blind" ones and damned near "vanished", a favourite trick since I was a cocky kid, still showin' off that long-handled "German pattern" hammer Herr Pelz had walked me through making for myself - then learnin' how to sorta "vibrate" for setting-down or crowning!
    Get connected with an old master as did his apprenticeship dawn of the 1900's Germany still "new" enough as an integrated nation he always called himself a "Schwabe", some Old Skewl ways were still first-choice and blitz-quick as well.
  17. Likes WillWilly liked this post
  18. #115
    Oct 2018
    Kentucky
    168
    6
    35
    Cool
    I think I have finished obsessing over the Taper Attachment. Finished the indicator with a 29mm magnifying watch crystal on top of a 29x1mm oring, then covered that with a 1.25"x1/8" glass disc on top of a 32mm oring.
    And, finished the new gear, drilling through the original taper hole, finally acquired the correct taper pin ream (#1) and installed. Works very smooth.
    So on to the shelf to make room for the next project.
  19. #116
    Dec 2016
    New York
    507
    7
    190
    My machine suffers from all the same conditions.
  20. #117
    Feb 2019
    Michigan
    113
    31
    33
    The 'good' thing about shimming in that location: it is easy to get to. If you change your mind, and need to or want to create a new gib, and scrape it in, it's not an all day job to get it apart..
    I'm pretty sure I could have my cross feed off and on the work bench in 15 minutes..
    Some shimming jobs are 'made in Heaven'.. some not so much: when you put the shims behind the gib, did the gib sit square, firmly in touch with the shims full length? It should have, since the shims are located where there is no movement or wear.
    The next determining evaluation would be: when you tighten the gib enough to get a slight drag, is that drag consistent over the full travel of the slide? If so, that's great.. but often the slide will be tight on one end of the travel or both.
    But if you know where it's slightly loose and where it 's tight, you can adjust your tooling to be where it minimizes your wear..
    All part of 'knowing' your machine..
    DualValve
  21. #118
    Mar 2011
    Geneva Illinois USA
    6,235
    2686
    2416
    From one who has done all the above to a 12CK, it was a lot of work put the machine back into first class capabilities. I did not regrind the bed, it was in very good condition, but I did remachine and scrape the dovetails of the cross slide and compound. The gibs had to either be replaced or shimmed. I chose to shim the compound .020 and braze up the cross slide gib. Adjusting the gibs was a problem at the time but have recently devised a method that works well to scrape the gibs. I revisited them and with just a small amount of scraping brought the compound and cross slide to a degree of smoothness and accuracy that is a pleasure use. Nothing worse than a gib that doesn't fit right.
    Tom
  22. #119
    Oct 2018
    Kentucky
    168
    6
    35
    Well looked it over several times and welding my broken cross slide wiper holder/guard was the best option.
    I attached the guard to the cross slide, ground v's in the crack 3/4's the way through the material, preheated, and welded with running tacks, post heated, let cool, ground, filed and flap wheel. I'm glad this was a success!
    It's the little things...
  23. Likes TDegenhart liked this post
  24. #120
    Oct 2018
    Kentucky
    168
    6
    35
    Quote Originally Posted by DualValve View Post
    DualValve
    Excellent advice. Mine has the wear you describe, it is good in the middle and snug on the ends. I was just determining how snug I can live with. Of course this would lead to scraping or milling the apron...
    I'm using a 12"x1/2" feeler guage as my shim. It contacts well and along the entire length. I can adjust out all play and still run to both ends, so there is still some life there... when I get to the apron, Ill look into a proper straight edge and see if it is in scraping distance.
    For now, I'm shimming and revisit if I need to.
    This ol production horse is going to pasture with only occasional riding.
