Monarch CY I need this part "Long Shot"
Results 1 to 6 of 6
    Oct 2018
    Kentucky
    168
    6
    35
    Cool Monarch CY I need this part "Long Shot"
    I'm looking for one of these. It is in the back of the cross slide, spring holer for the cross slide cover. Mine was torn off at some point...
    Oct 2018
    Kentucky
    168
    6
    35
    So since there isn't a part to be had, I'm making a new one.
    Made from a shoulder bolt McMaster number 91259A476, Spring 9657K308, and Steel tube 9220K471.
    I will machine down the tube to correct OD and Length, Machine the end disc, machine the head of the shoulder bolt to original dimensions (not really necessary), assemble and trim unwanted threads.
    Mar 2011
    Geneva Illinois USA
    6,231
    2682
    2415
    You are catching on to what must be done to resurrect machines long out of production.
    Tom
  4. Likes dalmatiangirl61, WillWilly liked this post
    Oct 2018
    Kentucky
    168
    6
    35
    Ta-Da. A small win!
  6. Likes Cal Haines, DualValve liked this post
  7. #5
    Feb 2019
    Michigan
    106
    31
    33
    Default Nicely Done.
    WillyWilly: that sure looks nice.. well done..
    A question: on the original part, was the larger diameter tapered edge end disc
    threaded onto the shaft ?
    Looking at your original and mine on my lathes, I can't tell if it was threaded or
    maybe peened on the end of the shaft, to retain the spring, sleeve and disc?
    Are you going to use Loctite, or maybe a single 'peen' with a prick-punch to
    keep the disc from coming loose ?
    DualValve.
  8. #6
    Oct 2018
    Kentucky
    168
    6
    35
    Quote Originally Posted by DualValve View Post
    DualValve.
    I could never tell if the disc was threaded or a press fit. I didn't want to take the only one I had apart since I planned on using. I did use Loctite on the threads and ordered the shoulder bolt to permit the disc to be tightened down on the shoulder. It works well and after trimming the excess threads, flap wheel on the face of the disc, it looks just like the original other than the fact I didn't take time to turn down the shoulder bolt head. I didn't really need to since it fit well.
    I would suggest using a shorter spring than I originally stated. I ended up using a 1" spring. It seem to give the same force than the original.
    I have extra parts if needed.
