Hobby Racer
- Apr 18, 2015
Machine: 1942 10EE Round Dial
I want to remove the bracket that holds the tachometer gears in place inside the headstock. Seems like it should be a simple task but like most other things on a 10EE it has taper pins. They seem to be blind taper holes AND they do not have threads on the top like the ones inside the back gear that let you lift them out by tightening a top nut.
Does anyone know how to get these out with out damaging anything?
I already removed the SHCS in the last picture.
