rimcanyon
- Sep 28, 2002
- Salinas, CA USA
I'd like to know more about the apron oil pump, so I pulled mine this morning. I wanted to flush the apron again anyway, the clean up and reassembly I did earlier this year loosened some sediment that you could see in the new oil. Also I am not satisfied that the pump is working correctly and I wanted to reseat both check valves. So in the process, I made some observations that I don't think have been mentioned in previous threads about this pump.
First off, here is a picture of the pump and the cam that drives it. Calcs are shown on the paper, sorry fo the small photo size:
Here is the lever arm that drives it:
So if my calcs are right, each full stroke of the pump moves the lever arm 0.186", and the lever arm has a 2:1.5 ratio, so the piston moves .14". The diameter of the piston is .152", so the displaced volume is .003375 cu. in. or .055 cc. not a lot.
The next thing I was interested in knowing was if the wear on the lever arm (where it rubs against the cam) had been corrected. I brazed the worn area and added about .1" of silicon bronze filler. After using it a couple months I could see where it was rubbing, and all looked good, but the question was still how to check if it was correct. I think the designers of the pump added a feature that makes that check very easy. On the bottom of the pump there is a ¼" hole. If you place a drill bit in the hole, it stops the piston rod precisely at the point where the piston is entering the outlet hole for the pump. Here are some photos that show this:
¼" drill bit inserted in the alignment hole:
The piston stopped just inside the edge of the outlet hole:
Note that the outlet hole is .093" dia, so if the piston is exactly mid-stroke with the drill bit inserted, it would have .07" of stroke remaining, which would take it to the edge of the outlet bore... very precisely made, these little lube pumps.
The next step was to see where that spot occurred when the apron hand wheel was rotated. Continued in the next post.
