motor generator & DC Motor lubrication
Results 1 to 10 of 10
    Sep 2002
    Salinas, CA USA
    4,838
    538
    446
    Default motor generator & DC Motor lubrication
    Searched the forum but did not find the answer: how many lubrication points are there for DC motor and motor generator?
    On my 49 10EE, there are two zerks on pipe extensions, one appears to go to either the front bearing in the DC generator, or the rear bearing in the AC drive motor. The other goes to the rear bearing for the 3HP Reliance drive motor.
    However, the manual I have (for a 58 Wiad machine) has this to say:
    Motor Generator and Exciter (Back of cover - three grease fittings - see footnote). The footnote says: No longer furnished. Electronic converter now standard.
    Main drive motor Grease every 12 mos. Sealed bearings, use caution to prevent seal blowout.
    So I seem to be missing some grease points.
    Jul 2007
    Missoula Mt
    1,422
    62
    702
    Very little, the damage that grease on the brushes will do is ugly...1 pump every 2 years...Phil
    Sep 2002
    Salinas, CA USA
    4,838
    538
    446
    Quote Originally Posted by Phil in Montana View Post
    Good point. On my machine, the only fitting is at the rear end of the DC motor and DC generator. No fittings on the exciter or the brush end of the other two. So maybe they eliminated fittings due to the problem you mention. Need to disassemble the units to lube the other bearings.
    Virginia
    20,829
    7561
    12208
    Quote Originally Posted by rimcanyon View Post
    "Brush end" of a round-dial's MG has a short pipe with a Zerk to the spider frame, bearing & brush-end being at the TS-end hatch.
    Piggyback exciter brush-end is directly above it, no pipe, Zerk right into the casting.
    That's on my '44. The "SSD'ed" '42's former MG is running some other Pilgrim's 10EE long-since. I palletized another one as well, but do not remember what is on the AC motor "fan end", and it is too nasty a task to crawl in and look at either that or the HS-ward end of the piggyback exciter atop it inside the belly of my '44.
    I DO "seem to recall" the exciter has a grease fitting operator side of the end frame, HS-ward end?
    As to final-drive motor, three of my four have the gearboxes mounted, but one happens to be separated, so...:
    Final-drive 3 HP large-frame has pipe IN and screw cap for purged grease egress at TS-ward end-bell. Open that exit cap before pumping in grease, pump 'til clean, and it stays in the reservoir, no slop.
    NB: Bearings aren't really meant to HAVE that much grease, but I'm not one to argue with what has JF run since 1942, so I've NOT gone over to sealed bearing replacements.
    As to the end at the brushes and gearbox flange, the bearing is, AFAIK, sealed only at the brush carrier side, is visibly unsealed, gearbox & gearlube side, ergo lubed by slosh, splash drip, and run (a firm of Lawsters, izzat?) of the gearbox oil supply, not by grease.
    2C, One MG, four large-frames worth.
    Sep 2002
    Salinas, CA USA
    4,838
    538
    446
    Thanks Bill, but as I said, I see nothing in those locations on the 49. Would like to hear from someone with a similar vintage machine to mine, or newer. If you have the grease fittings, please post a photo.
    Virginia
    20,829
    7561
    12208
    '49 could have been entry to "sealed bearings" era, then?
    Plugged at the old locations, I'd class user/rebuilder solution.
    Never drilled would not be an oversight. Factory bearing choice change, rather.
    Sep 2002
    Arizona
    4,090
    1029
    681
    Dave,
    My 1948 square-dial DC motor has a brass tag on it that calls for greasing the motor twice a year. It also states that the bearings are double-shield ball bearings. I think the tag only applies to the rear bearing; it appears that the motor's front bearing is lubricated by oil from the back-gear unit. Looking at the back of the motor, there's a threaded hole for a grease fitting at 9 O-clock and a plug to let out excess grease at 4 O'clock.
    The front bearing is a Federal 207 FF. I don't know about the rear bearing.
    Cal
    Sep 2002
    Salinas, CA USA
    4,838
    538
    446
    Thanks, Cal.
    That is an interesting plate. It says ... force in grease until just ⅛ inch comes out any hole of the keystone fitting.
    I googled keystone fitting, but its meaning is unknown to Google...
    Sep 2002
    Arizona
    4,090
    1029
    681
    I don't know either. I think you're supposed to pull the plug at 4 O'clock and add grease until a bit comes out the plug side, but there's only one hole there, so "comes out any hole" makes no sense.
    Cal
    Virginia
    20,829
    7561
    12208
    Thanks, Cal.
    Not "unknown". Just pre-internet. 1954 the most-recent version patented.
    Grease relief fitting - KEYSTONE LUBRICATING COMPANY
    Keith's site had a trail on "Keystone:
    Keystone Lubricating Co. - History | VintageMachinery.org
    ..that led to:
    Keystone Lubricants Div., Elf Lubricants North America, Inc.
    Elf then became part of "Total". Outta France, IIRC?
  11. Likes rimcanyon liked this post
