My first ever lathe! - CK 12, I think ?!
Results 1 to 16 of 16
    May 2020
    AUSTRALIA
    6
    Default My first ever lathe! - CK 12, I think ?!
    Hi All! Well, ive wanted a Lathe for over 20 years, and yesterday was finally the day! A mate of mine that works in machining, managed to get me an old 1943 Monarch lathe for about $500US (Im in Australia)
    Now, please go easy on me guys, I don't really even know the correct terminology for stuff yet, im 'very' new to anything like this, but hoping I can gain some info from you knowledgeable blokes!
    So, as far as I can tell, its CK 12", the plate with the model number on etc, is fairly hard to read...so could be a CY, or CK on there...hard to tell.
    Im assuming they are a fairly capable lathe ?
    May 2020
    AUSTRALIA
    6
    My mate told me he ran it and checked it, the main gearbox seems to be smooth, but the part that does threaded etc didnt seem to engage. And the belts need to be tensioned.
    I decided that before I ran it I wanted to check oils etc, so in the afternoon I took the top of the main gearbox and although the lathe itself looks likes its been feed more than its share of hot suppers, it was reasonably clean inside.
    Ive read that this old girl needs SAE 30 oil, does that sound correct ? Also, I have no idea where the oil level should be?!?
    There does seem to be workshop manuals available, but only in the US and wont shop to AU. Does anyone know if there might be an online version perhaps ?
    My plan at this point is to simply get it working, and then slowly rebuild it as I get more familiar with it. Imagining this beasty back in its former glory makes me happy!
    Dec 2016
    New York
    549
    7
    200
    First things first. If you are new to machine tools, i recommend you study up on safety precautions when operating a lathe and take them very seriously. This machine can easily maim or kill you if you are not careful.
    Machine tools when operating are a bit like fire, beautiful, elegant and useful but get too close and you get burned.
    Jun 2012
    Michigan
    11,300
    3870
    3990
    Good to brush off everything you can .. pick off any chips ..then begin to wipe it with an oiled rag untill it looks clean..a little mineral spirits in the wipe oil is good..
    Dont wire brush or air blow anything..
    QT:[Im assuming they are a fairly capable lathe ?] one of the best..
    Good to hand roll the chuck to be sure you dont have a locked gear till you get uses to the gears.
  5. Likes Glen_Oz liked this post
    Jul 2004
    Houston, TX USA
    30,729
    I can try emailing the 15Mb manual scan if you want to Private Message me that email address - its but 21 pages, but all Monarch manuals of the period were quite slim. In case not known, this won't teach you anything about RUNNING a lathe.
    This would be more help in that direction
    http://vintagemachinery.org/pubs/1617/5795.pdf
    Your photo unmistakably says 12 CK
    I run ISO 68 (Mobil DTE Heavy Medium) in my CW 16 and have for over 20 years - this is some lighter than "30 weight" - and is actually intended for machine tools - unlike "motor oil".
    Oct 2018
    Kentucky
    213
    14
    47
    Glad to hear about your find. I'm in the middle of my rebuild 16" CY, very similar. Look at thread, Monarch CY 16 Winter Project. It should answer a great deal of questions.
    I agree, if you are not experienced with running a metal lathe, please follow marka's advise above and get yourself schooled. This lathe, as with many, will not know the difference between metal or your limbs...
    A good cleaning is in order, make sure your oiling systems are functioning in the headbox and saddle/apron. Again look through my thread and it will explain oiling system, oil pump function, and hopefully more than you need to know.
    Don't hesitate to ask questions here... Alot of great folks!
  8. Likes Glen_Oz liked this post
  9. #7
    Sep 2002
    Arizona
    3,719
    918
    504
    You might have a look for manuals on Vintage Machinery (link). There are also dozens of brochures going all the way back into the 1920's, most of which were posted by Keith Rucker.
    Cal
  10. Likes Glen_Oz liked this post
  11. #8
    May 2020
    AUSTRALIA
    6
    Quote Originally Posted by marka12161 View Post
    Thanks for the advice, and I hear ya. While its been many years, in New Zealand, they taught lathe work in late high school, and one whole semester was basically machinery safety, with some pretty graphic demonstrations, and its still with me to this day.
  12. #9
    May 2020
    AUSTRALIA
    6
    Quote Originally Posted by johnoder View Post
    Thanks mate! I would really appreciate the manual if thats ok.
    I did find this one online - http://manuals.chudov.com/Monarch/Mo...N-W-Lathes.pdf
    It wouldnt be the same one ?
    Ill look further into the oil, sounds like SAE 30 might be a bit out dated.
  13. #10
    May 2020
    AUSTRALIA
    6
    Quote Originally Posted by WillWilly View Post
    Thanks! Ill have a good read before I go much further. I have my mate coming around tomorrow to go through a bunch of stuff with me too.
  14. #11
    May 2020
    AUSTRALIA
    6
    Yesterday, I hooked up the VFD and after putting some oil in the headstock, I ran the lathe real slow. Except for a little belt slap, it ran very smooth, so will have to adjust the tension at some point.
    Today, I wanted to check the apron, after dropping the pump cage off the side, I found zero oil and a reasonable amount of crud in there that I wanted to clean out, I tried just blasting is out with a bit of degreaser, but ultimately decided I would need to split it all, hoped I could just lift the saddle and get in through the top to clean the apron out.
    I must admit, I ran in issues here, I removed the 8 obvious bolts at the top, the adjuster, the dowels and the clamps under the CS, and while the rear saddle is free, its still held in place at the front somehow, is there a trick to getting the saddle lifted ? I could only find 10EE stuff with a search.
    I also found that the far right 'short' bolts connecting the saddle to the apron had been stripped, is there an accepted fix for something like this ? Helicoils ? What thread is this even ?
    I thought while I was checking things I would have a quick look at the Cross slide gearbox, while this looks like it should be full of oil, it was just packed with a bit of grease, is this common mod ? Maybe they leak too much ?
    Hope everyone is keeping safe and enjoying some isolation time with their lathes
  15. #12
    Jul 2004
    Houston, TX USA
    30,729
    Does Monarch use "hold downs" under the bridge of the saddle? I know the larger Lodge & Shipleys do - like my past a hundred-year-old 24"
    It wouldn't be the same one ? (manual)
    Pretty much looks like
  16. #13
    Sep 2019
    Tennessee
    45
    9
    12
    Being only about 9 months ahead of you, here are the toe-holds that I have found most valuable.
    1) Go to Youtube and watch lathe accident videos to instill a healthy respect for the machine.
    2) The Youtube channels Vintage Machinery and Machining 360 both have lots of detailed videos about rebuilding Monarch lathes. Even if they aren't the exact model, many of the details are the same.
    3) There is loads of good info in these forums. I always search google for "<my issues> site:practicalmachinist.com" and rarely do I NOT find the answer. In particular, WillyWilly's thread has saved me an enormous amount of floundering around on my own.
    4) The Youtube channel Blondihacks has a series on basic lathe use that is a very concise introduction if you are like me and starting with zero knowledge.
  17. #14
    Oct 2004
    Illinois
    961
    155
    139
    Wow, you got a raised in the sand version with a lot more swing than standard
    John
  18. #15
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,147
    450
    1077
    What is up with all of those rods going thru the cross-slide? Is there power to the compound?
    Mine does not look like that!
    I ended up taking a gear out of the end train, was a lot of gear whine and that was simplest I could do at the time.
    The half nut engage (lever with threaded end) also doesn't look like mine, its sort of a cast ball-handle with an offset bend. Was once chromed before its poor storage environment got to it.
  19. #16
    May 2020
    Indiana
    9
    On mine, a ‘44 CK, in addition to the 8 bolts, the saddle has clamps under the bed, both front and rear that need to be removed. Also there are 2 alignment pins threaded into the front on the extreme left and right that have standard screwdriver slots in them.
