New to me 10EE, how to start spindle?
Results 1 to 8 of 8
    Mar 2013
    Danville Virginia
    112
    37
    Default New to me 10EE, how to start spindle?
    Sorry for the rookie question but I'm trying to get this lathe running for a friend. Turns out it's 220 single phase, which we've stepped down from 460 with a transformer. Machine seems to turn on, ON light comes on, fan runs. Manual is 1972, machine is 1969 so the spindle control lever is not where the manual says it is. I assume it's the lever in pic #1. This machine has the "electric leadscrew reverse" so the lever does not connect to a drum switch. There are 3 switches on the tailstock end that engage the motor apparently. The spindle will not start. Am I missing something on the start-up procedure? TIA.
    Mar 2002
    dallas,tx
    2,455
    512
    437
    There should be a lever on the apron, bottom RH . The apron has the big handwheel and the dial things. The lever shown is the gearbox tumbler lever, to change thread gearing on the gearbox.
    Sep 2002
    Arizona
    3,554
    777
    468
    Quote Originally Posted by slowmotion View Post
    ... Manual is 1972, machine is 1969 so the spindle control lever is not where the manual says it is. I assume it's the lever in pic #1. This machine has the "electric leadscrew reverse" so the lever does not connect to a drum switch. ...
    Here's a link to the 1965 manual, but I doubt it's much different from your 1972 manual. The Electric Leadscrew Reverse option is covered on pages 8 and 9. Look at figure 11. Lever B controls the spindle, in conjunction with knob G on the right end of the bed. There are also several interlocks that will keep the spindle from starting, but it's been years since I ran a "Modular Drive" machine like yours, so others will be better able to help you there.
    Cal
    Nov 2004
    Webster Groves, MO
    7,043
    1743
    3151
    There is a neutral position on an ELSR switch that will keep it off. Switching it to forward or reverse will allow it to start. That is the rotary switch on the tail end of the bed.
    Bill
  5. Likes old_dave liked this post
    Mar 2013
    Danville Virginia
    112
    37
    OK thanks, great replies, gives me several things to check tomorrow. I will give a full report when it's burnin' gas.
    Nov 2004
    SLC, UT
    678
    860
    129
    The speed control is the round chrome knob located near the backgear lever (far left end of the front of the machine). Think it is good practice to turn it all the way counterclockwise before starting the spindle via the spindle lever or ELSR switch, then gradually ramp it up.
    The safety interlocks Cal mentioned: there is a relay on the spindle lock (chrome knob at the top right of the headstock cover), a solenoid on the front electrical panel door, and a solenoid on the back gear to prevent shifting above 200rpm(or so).
    Mar 2013
    Danville Virginia
    112
    37
    Solved. Turns out the interlock for the front panel door is bad, the door can open when the machine is turned on. So I pulled the plunger down, wrapped a cable tie around it, now the spindle comes on. Thanks for the support, surprisingly friendly responses considering such a rookie question!
  9. #8
    Virginia
    25,713
    7561
    8100
    Some were about to ask for pictures when you said "burning gas". Steam having been done, arredy.
    As with "country boys", a 10EE "can survive". Thing is, they can last longer than we do.
    So we all starts out "rookies", then comes back to that state as old age has us ferget and have to ask it all again...
