New to me Monarch 10EE just arrived! - Page 13
Page 13 of 13 FirstFirst ... 3111213
Results 241 to 250 of 250
  1. #241
    Apr 2011
    Wisconsin
    365
    135
    89
    Meanwhile back at the mill (literally).
    I was cleaning up some rash on the cross slide...mostly cosmetic. I put a .125" x 4.80" chamfer on top edge of the cross slide assembly. Looks a lot better.....have to sharpen up some scraping tools now
  2. Likes Zap921 liked this post
  3. #242
    Mar 2002
    dallas,tx
    2,504
    551
    459
    A nice scraping job will cover alot of cosmetic blemishes, ask me how I know this And if scraped all flat and square, makes it much easier align everything back up, moglice, turcite, etc.
  4. Likes rakort liked this post
  5. #243
    Apr 2011
    Wisconsin
    365
    135
    89
    So back at it a little in between working the 68 GTX.
    One more pile of parts off the bench.
    Thanks cal for the dimensions on the x-slide lock screw
  6. Likes daryl bane, rke[pler, TheOldCar liked this post
  7. #244
    Apr 2011
    Wisconsin
    365
    135
    89
    ok its been a while since the last update on the lathe refurb/cleanup
    New to the project is an upgraded tailstock. Thanks to member bsg aka Kevin, I acquired a large quill tail stock. The quill and quill bore were in great shape so it was a nice upgrade. Turns out the base of the acquired tail stock was about 20 thou thicker (and more worn) than my original so I fit my original base onto the new tail stock "top" and rolled the dice. Pretty much won the tail stock lottery because as it turns out the combo of the OE base and the new "top" put the quill about 1 thou higher than the spindle. Now I just need to use it a little and wear that 1 thou out. I also splurged and bought a new nut from miller machining resulting in about 5 thou backlash on the screw.
    As found
    Parts
    Checking out the bases
    Checking alignment
    and on to next project
  8. Likes TheOldCar, Cal Haines liked this post
  9. #245
    Apr 2011
    Wisconsin
    365
    135
    89
    Now what to do with this one
  10. #246
    Virginia
    27,700
    7561
    8621
    Quote Originally Posted by daryl bane View Post
    A cleanly refinished compound and cross pragmatically make it easier to set and manoeuver a mag-base DTI holder or take a height or angle measurement than dealing with a random rash of dings and burrs.
    More to it than just "looks good" IOW. Works better for you as well.
  11. Likes rakort liked this post
  12. #247
    Virginia
    27,700
    7561
    8621
    Quote Originally Posted by rakort View Post
    For starters.. you have all the handles intact, it ain't a block of rust, so even IF is still needs milled, shimmed, scraped for some other 10EE fitup, I suspect you'll find a buyer.
  13. #248
    Feb 2019
    Michigan
    105
    30
    33
    Rakort: please check your email messages.
    DualValve.
  14. #249
    Apr 2011
    Wisconsin
    365
    135
    89
    Thanks for the terse response, I appreciate it! My attention span was even long enough to read through the WHOLE thing!
  15. #250
    Virginia
    27,700
    7561
    8621
    I din't use no "W" in that?
  16. Likes rakort liked this post
