Newbie question: if this an M-G motor?
Likes Likes:  0
Results 1 to 7 of 7
    Jul 2018
    North Carolina
    72
    20
    Default Newbie question: if this an M-G motor?
    I've been working from the top down on a 1942 10EE and today, pulled the coolant pump and the motor. I keep readying all these messages about the various motor types. What is this one? There isn't a tag anywhere on it. (I can see where the tag used to be.)
    My plan is to pull it apart and clean/check the bearings.
    Am I right in presuming that the front bearing on this motor gets lubricated from oil in the gear reduction box hung off the front?
    Mar 2016
    Louisiana
    356
    191
    66
    That is a large frame dc motor for the spindle. 3 HP
    Apr 2011
    Wisconsin
    303
    102
    70
    Quote Originally Posted by focusrsh View Post
    Do pull it apart and check/clean the bearings. I did the same to mine. I pulled off one end bell at a time and never removed my armature. No the front bearing does not get lube from the gearbox.
    You can see some pixs on my build thread doing the same.
    You should feel good about that motor because like mine it "seems" to have been through a motor shop within the last few decades. It looks quite clean and serviceable.
    Virginia
    26,062
    7561
    8224
    That's one of the Tyrannosaurus Rex of Dinosaur Current. large-frame "Type T". The legendary Reliance Electric & Engineering turbine-smooth elevator/hoist motor, as adapted to MG-era 10EE. Tag photos are on PM.
    Treasure it. It is one.
    Jul 2018
    North Carolina
    72
    20
    Quote Originally Posted by labeeman View Post
    OK, that explains the 3H KB motor controller that is on this lathe.
    Funny that is has a "Property of US Navy" and serial # tag. Since it isn't original to the 10EE, I'm stumped. Did the Navy retrofit this motor? If so, they also retrofitted the coolant pump, which has an identical tag, one serial number different. I suppose someone bought a pump and motor from Navy surplus, but with sequential serial numbers?
    This is like peeling an onion. Or exploring King Tut's tomb.
    Sep 2002
    Arizona
    3,581
    798
    473
    That's very likely the lathe's original motor. That's what they look like, sans back-gear unit.
    Cal
    Virginia
    26,062
    7561
    8224
    The original question has been answered.
    UNSOLICITED post on drive conversions is off topic and has been deleted.
    THREAD LOCKED.
