No 19 TPI on my EE, Why?
Results 1 to 17 of 17
    Mar 2002
    dallas,tx
    2,439
    499
    431
    Default No 19 TPI on my EE, Why?
    I was doing a bunch of British BSC, BSF and BSP stuff, and was astounded that my EE had no provision for 19 TPI on the gearbox. Seems 1/4-19 BSP is a relatively common thread around the world.
    Jul 2008
    South Carolina
    576
    178
    324
    Apparently not commonly found on old American iron checked my lathes all went from 18tpi to 20tpi.
    Oct 2015
    AUSTRALIA
    40
    13
    The first version of my lathe, an EE clone by CVA (later Kearney trecker UK) didn't have 19 but the later machines do, changed sometime pre 1964.
    Sent from my Nokia 8 Sirocco using Tapatalk
    Jul 2004
    Houston, TX USA
    28,964
    So stick in a 95/100 compound and charge ahead
    Oct 2010
    Moscow,Idaho,USA
    1,043
    1195
    459
    The Rivett 1020S has 19 tip.
  6. Likes traditional-tools liked this post
    Mar 2002
    dallas,tx
    2,439
    499
    431
    I guess I'll just have to use my Chinese Enco backup lathe. It has 19TPI.
  8. Likes rustytool liked this post
  9. #7
    Jun 2007
    Nevada
    362
    28
    Daryl, I’ll make you a 95/100 Gear if you can wait a bit.
    John
  10. Likes daryl bane liked this post
  11. #8
    Mar 2002
    dallas,tx
    2,439
    499
    431
    After I sent John a PM on his offer, and said I just had a couple of these to do, I got curious on the math involved. So if I did change out the compound gear to 95/100, how does this work ? What combination of the settings would get a 19 TPI? Sorry I am just a bit slow in the brain dept.
  12. #9
    Nov 2007
    San Diego
    65
    5
    9
    The 95/100 gear ratio is the same as a 19/20 ratio (divide both numbers by 5 to see this). So the 95/100 gearing lets you convert the 20TPI setting on the machine to actually cut 19TPI.
    Other thread settings that can work abound mathematically but perhaps not physically. For instance, to cut 19TPI using the 23TPI setting you would want gears with a 19/23 tooth ratio, or 38/46 (double the tooth count), or 57/69 (triple the tooth count), or 76/92, or ... you get the picture.
    Any thread selection on the machine can be mathematically converted with the right gears to cut 19TPI, but those gears may not be physically realizable.
  13. Likes daryl bane, Cal Haines, Ohio Mike liked this post
  14. #10
    Jun 2007
    Nevada
    362
    28
    I said 95/100 as a quick answer, but the practical way to do it is make the 60 tooth idler a compound 57/60 tooth and then flip it over so the 24 tooth stud mates with the 60 and the 57 drives the downstream gears. 57/60 = .95
    John
  15. Likes daryl bane liked this post
  16. #11
    Jun 2007
    Nevada
    362
    28
    Upon further thinking since the gearbox has a 12 thread setting, simply replacing the 24 tooth stud with a 38 tooth stud would work. Much easier than making a 57.
  17. #12
    Virginia
    24,213
    7561
    7585
    Quote Originally Posted by Jimbojet View Post
    ..or some of those "realizable" may be of no initially obvious use.
    My I/M HBX-360's "Whitworth-Sellers-Briggs" (AKA "inch") selector also lacks the 19 TPI sought here..
    But it DOES have a setting for "19 1/5".
    Anyone know what THAT might be used for? Besides the metrifucated French mebbe simply takin' the piss 'coz the rest of the geartain happened to provide it (plus a few OTHER "fractionals") as a byproduct?
  18. #13
    Jul 2004
    Houston, TX USA
    28,964
    Quote Originally Posted by bll230 View Post
    Maybe not - 12 TPI is .08333" lead. Multiplying that by 38/24 just makes it a larger lead
    19 TPI is but .05263" lead
  19. #14
    Jun 2007
    Nevada
    362
    28
    Dawggone it John, you are right. I am so used to working with gears I forgot to hit reciprocal on my calculator. In my pilot business it is called expectation bias. I produced the answer I wanted to get. Italian wine is my second hobby - I shouldn't post math responses after dinner!
  20. Likes daryl bane liked this post
  21. #15
    Mar 2002
    dallas,tx
    2,439
    499
    431
    So what is the consensus of the best way to go about this, a 95/100 compound gear or a 57/60 as bll230 suggested?
  22. #16
    Virginia
    24,213
    7561
    7585
    Quote Originally Posted by daryl bane View Post
    Where taps and dies can't work? Or sometimes even where they might?
    Farm it out to he with CNC, else "no bid" it.
    Done the numbers on recovering the T&M costs?
  23. #17
    Mar 2002
    dallas,tx
    2,439
    499
    431
    Parts were done successfully on my dreaded "thou shalt not be named here lathe". But I have rec'd VERY kind offers to make a proper gear to do this on my EE. So what I am asking is, if we are going to make a gear what is the best spec, teeth, etc. to make a correct gear?
