Nosepiece dimensions
Likes Likes:  0
Results 1 to 8 of 8
    Jun 2003
    Mebane North Carolina USA
    6,712
    53
    1937
    Default Nosepiece dimensions
    Anyone have a print for the EE nosepiece for use with the handwheel closers?
    Sep 2007
    Spanish Springs, NV
    2,365
    155
    292
    I doubt anyone but Monarch has that print. Call them.
    It's a crafty piece of work. Hardness was not uniform through the tool, Monarch was a master at putting material properties exactly where they wanted them with the technology known at the time.
    Flame hardening anyone?
    Oct 2012
    Virginia
    10,264
    5843
    4629
    Quote Originally Posted by DaveE907 View Post
    I'd rather suspect simple 8620 and case hardening would do well-enough.
    5C is GOING TO try to lobe any closer it is used with. Given time enough, eventually it succeeds.
    Easy enough on draw-tube goods to bless it with an in situ regrind ever' so many years.
    Or decades.
    Bill
    Sep 2002
    Salinas, CA USA
    3,900
    209
    177
    I've seen posts on this forum that said Royal also made a 5C D1-3 nosepiece, so you might be able to get a print from them.
    Jun 2003
    6,712
    53
    1937
    I dont need every dimension, just from spindle face to end of adapter.
    Feb 2007
    upton ma
    1,668
    48
    173
    OK have the one I picked up a few years ago sitting here on my desk. It is unfinished - the D1-3 taper was never finish ground, same for the 5C. I checked the hardness of the flat facing the front of the nose which averaged about 53. And no I have not finished it yet - dont have a 4 jaw big enough to properly hold it and not sure I really trust myself to get the precision desired.
    So what dimension do you need? Spindle face to end of adapter sound like overall length? And how accurate do you want the dimensions? Hand drawn sketch and I'll pull what you need?
    Paul
    Jun 2003
    6,712
    53
    1937
    Spindle face to end of adapter is what I need. Maybe OD. Caliper tolerance would be fine. Careful tape measure?
    Feb 2007
    upton ma
    1,668
    48
    173
    Spindle face to end (flat on spindle - not the D taper sticking out from there) to front of nose is 3.20" dia is 3.760" taken over the knurl - widest part.
    Remember this is an unground part which I assume to be original (no clue why an unfinished part wound up in the wild.
    Paul
