Old monarch?
Likes Likes:  0
Results 1 to 4 of 4
Thread: Old monarch?
    Oct 2008
    Conyers GA
    176
    5
    Default Old monarch?
    Is this a Monarch model A? The spindle looks a bit different. The back gear shaft also looks like it's missing a gear or two.
    Attached Thumbnails Attached Thumbnails img_20190302_134318863.jpg   img_20190302_134509479.jpg   img_20190307_183917177.jpg   img_20190307_204433620.jpg
    Jul 2004
    Houston, TX USA
    28,854
    One of the gear box / drive on top jobs? - the more or less central "looks-like-a-gear" is a silent chain sprocket
    May be a "B" - larger than an "A"
    Here is a local (cone ) one - referred to as an A but maybe a B
    Monarch lathe model A - heavy equipment - by owner - sale
    Maybe slightly before this "formal" gear head
    http://vintagemachinery.org/pubs/2103/19577.pdf
    Oct 2008
    Conyers GA
    176
    5
    I'm told there may still be a 3 speed gear box for the lathe in the building I got it from.
    Despite being exposed to the weather for who knows how long...
    I got the spindle removed easily. The bronze bearing need to be at least honed.
    The quick change gearbox is freed up and everything is now turning easily. The tumbler lever is still stuck as of now.
    All gears on the end of the lathe spin.
    Got the saddle unbolted from the apron. The inside of the apron is rust free.
    The list of things still frozen on the lathe are as follows...
    The chuck
    Tailstock spindle
    The back gears are stick to their shaft and won't spin. But the back gear lever will rotate the shaft in and out of engagement.
    Lead screw
    Feed rod
    Oct 2008
    Conyers GA
    176
    5
    The lathe swings about 14" over the bed. I'm down to having the lead screw, feed rod, tailstock and back gears to free up.
    How does the compound remove from the cross slide?
    Any hope of finding a picture of the threading and feed chart?
