Old Monarch questions with photos
Likes Likes:  0
Results 1 to 11 of 11
    May 2011
    Oakway, SC
    5
    Default Old Monarch questions with photos
    I was given an old Monarch lathe with an 8 foot bed. I would to identify it and find someone with a manual for it. It has a patent date of January 23, 1906.
    I will try to post photos.
    Thanks, Richard
    Where would I find the serial number on this lathe.
    Attached Thumbnails Attached Thumbnails monarch-lathe-002.jpg   monarch-lathe-2-003.jpg   monarch-lathe-003.jpg
    Feb 2004
    Baltimore, MD, USA
    4,027
    292
    588
    Looks like a Model A. I have a couple docs here
    http://pounceatron.dreamhosters.com/docs/index.html
    towards the middle of the page.
    Regards,
    Greg
    Oct 2004
    Illinois
    951
    149
    134
    Quote Originally Posted by Richard H. Gambr View Post
    Thanks, Richard
    What is the swing of the lathe? 12 is a Model E 14-16" is a Model A; 18-20" is a Model B and 22" and bigger is a Model D.
    The patent is for the quick change gear box which Monarch Licensed from Flathers in 1912. This means your lathe was built sometime after that. Most likely your lathe was built during WWI where Monarch built several thousand lathes from 1915 through 1919.
    John
    Apr 2011
    Florida,USA
    Do all Monarch Lathes have the date of manufacture on the brass thread and feed tag? My model A has no date on the tag, It looks like the one shown only mine is 6 foot overall length.
    May 2011
    Oakway, SC
    5
    Thanks for the info. It is apparently a Model A with a 16 inch swing. I use it quite a bit in my farm shop and more recently, in making a line boring rig for Model T Ford main bearings. I am sure I will have many more questions as I want to learn to cut threads with it. I need to make a new piston rod for my steam engine soon.
    Gonna start combining wheat today, so my other projects have to wait a while.
    Richard
    Oct 2004
    Illinois
    951
    149
    134
    There is no way of dating early Monarchs before they started to use serial numbers in 1927. Before this all lathes were built in lots and the lots numbers got rolled over which makes it difficult at times to find. Monarch Lathes use to have all these old records, and sometimes were able to find these lot numbers and date the lathe.
    Monarch made most of their cone head lathes during WW1, and a lot of these where shipped overseas. Monarch suffered a sever slow down right after the war, and before the war they were working hard to establish themselves so their pre-war numbers are limited. In 1917 and again in 1918 Monarch built over 3,000 lathes of all sizes.
    One big identifier is when Monarch came out with the cone clutch apron in 1923, with all lathes after this had this having this feature. Next was the switch to the helical geared lathe in 1926 which nearly wiped out the production of cone head lathes there after.
    Do a search on monarch history and you will find more detial on this that I have posted in the past.
    John
    May 2011
    Oakway, SC
    5
    Thanks John
    Apr 2011
    Florida,USA
    John, My lathe has only one star shaped dial on the apron, the other is a round knob is this the cone clutch you are talking about. I was told it was a 1924 or 1925 model year, as stated before no pat. date on tag.
    Oct 2004
    Illinois
    951
    149
    134
    no the cone clutchs are lever operated and there will be two of them.
    May 2006
    Salisbury, NH USA
    Default WW-I Monarch
    Perhaps of interest, I also have a Monarch very similar to the one in photos above, 12" swing X 8' bed. I've had it for about 10 years and I've tried to use it but the spindle keep lifting during medium to moderate cuts. Everything is so large and heavy and I'm so old and feeble it is difficult to disassemble things and figure out what's wrong. I'd love to get the old dear back on her feet if I knew where I should start and what to do.
    I also need to replace the carriage rack gear because it seems someone left the feed engaged and then took lunch break and forgot about it. I'm told it's a 14½ PA rack available from Boston Gear.
    I don't mind spending some money on it if I had something to go by to fix it.
  11. #11
    Sep 2007
    Spanish Springs, NV
    2,365
    155
    292
    The spindle "lifting" or moving around in any manner means the spindle bearings are worn excessively. Are you up for repairing them? Until the spindle bearing system is good ignore the carriage rack gear, it is of no use.
