For owners of 61 Series Monarchs... What oils and lubricants are you running?
Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    May 2010
    Palo Alto
    52
    12
    21
    Default For owners of 61 Series Monarchs... What oils and lubricants are you running?
    The subject says it all... almost....
    I recently acquired 61 Series lathe in excellent condition complete with tooling and operators manual. The manual calls for Vactra heavy medium oil for the headstock reservoir and several other places. I thought this would be an easy one for my tool supplier but not so much. His reference chart only shows Vactra oils #1-4, and the only heavy medium that comes up is dte.
    Searches here and elsewhere have yielded much information most of it conflicting I'll settle instead for the collective wisdom of fellow owners.
    Sep 2013
    Oregon
    80
    123
    35
    Traveling....will look on Tuesday
  3. Likes Rakker16mm liked this post
    Oct 2012
    Virginia
    10,264
    5843
    4629
    Quote Originally Posted by Rakker16mm View Post
    Search deeper in the forum.
    Any cross-ref for 10EE, of which there are 3 or 4 goods ones at least, will ID the modern equivalents to older lube branding. Whether the 61 uses any given lube in the same place or not, you'll have your 'table' info.
    And yes, there are 'discussions'. Not always of differences that actually matter.
    Ex: I used what was finally agreed was the 'not quite right' one in my 10EE spindle.
    It was 2d choice anyway, it only holds about 3 ounces out of the two gallons purchased. The lube has another use in the shop. So I'll just do an early drain, flush, refill with the 'more correct' one.
    BFD.
    Now don't ASK what a six-speed ZF transmission wants in the way of fluid ounces of liquid money - just for MULTIPLE flushings - when used in an XJ8-L... 'of mature years'.
    Bill
  5. Likes Rakker16mm liked this post
  6. #4
    Mar 2014
    84
    7
    11
    I found the same when I searched as well. I got a gallon of DTE but I'm not sure if I'm gonna use it.
  7. #5
    Jul 2011
    Utah
    976
    2137
    400
    Vactra 2 for the ways (way lube). Fill the carriage with this stuff.
    The headstock and gearbox both take an ISO 68 that I can't remember the proper cross reference to.
    I'm sure searching here turned up the proper oil equivalents...I just need to go check them again. I have been using tractor hydraulic fluid that is ISO 68, but I think it is not the best idea (again, if I'm remembering correctly).
  8. Likes Rakker16mm liked this post
  9. #6
    Jul 2011
    Utah
    976
    2137
    400
    DTE heavy medium is the right stuff for the gearbox and headstock.
  10. Likes Rakker16mm liked this post
  11. #7
    Oct 2012
    Virginia
    10,264
    5843
    4629
    Yes, but.. Not one of the "numbered" 'turbine' oils on the DTE menu, this one has a name.
    I am looking right at a gallon from usenco.
    Sez, line by line:
    Mobil
    DTE Oil Heavy Medium
    Premium R&O
    Circulating Oil
    Heavy Medium
    ISO 68
    Then lapses into Spanish for the American market and French for the Canadian market...
    Bill
  12. #8
    May 2010
    Palo Alto
    52
    12
    21
    Quote Originally Posted by Monarchist View Post
    Sez, line by line:
    Mobil
    Premium R&O
    Circulating Oil
    Heavy Medium
    ISO 68
    Bill
    Bill, I'm not sure what you are trying to say. Are you saying that dte heavy medium is the right oil?
  13. #9
    Sep 2007
    Spanish Springs, NV
    2,365
    155
    292
    Not Bill here.
    The text he related to you off his container is correct and it is a recommended formulation for your application.
    The Mobil dealer in San Jose has it in five gallon pails if you just want a little bit. That's how I bought it when I was running my shop.
    What seems to be the hurdle for hobby sorts is a source for gallon size. Sources come and go over the years. You just have to do the research to find the available best provider of what you seek.
    At times both McMasterCarr and ENCO were sources, your mileage might take another path. Pay attention to price on the net, there are lots of ripoffs available.
    I did some posts awhile back on the then current best source, good luck.
  14. #10
    May 2010
    Palo Alto
    52
    12
    21
    Dave, what dealer do you use in San Jose? I was located in Menlo Park and just move the shop to Oakland. I've been buying my oil from Western Tool and Supply. They get their oil from Flyers formerly Redwood Petroleum. Flyers doesn't seem to stock the lubricants I need, and it takes a long time to get what I need.
    It does appear that DTE Heavy Medium is the correct option. I try to get a manual with every time I acquire a pice of machinery for the shop. Of course all my equipment is at least 30 years old, and the petroleum industry seems to like swapping and changing names quite a bit.
    Buying in small quantities is a problem for me since at least two of my machines, the Monarch in particular take about five gallons to fill up. Since I hate waiting on oil I'm thinking of purchasing in 55 gallon quantities.
  15. #11
    Oct 2012
    Virginia
    10,264
    5843
    4629
    LOL! Well there yah go. There are Monarchs and.... there are OTHER Monarchs.
    Figured TWO one-gallon jugs of DTE Heavy Medium was overkill for a 10EE's needs. But that I might have one get punctured and leak away, plastic as they are. Or get contaminated.
    So.. Good to have a spare.
    Bring a 55 gal drum into MY shop, I'd have to have long enough arms to work from outdoors for lack of space. Or hire Bubba. Y'know .. the guy whose knuckles drag on the ground when he walks.
    Meanwhile.. the usual story from suppliers;
    We have two sizes!
    Too big.
    And not small enough.
    A pallet of 5-gal pails might be less risk than a single 55 drum. Lybarger's Corollary 'sez soon as you have plenty of lube, the machine tool as uses it will be traded-away. And then you have a disposal issue.
    Bill
  16. #12
    Sep 2013
    Oregon
    80
    123
    35
    I'm running Mobil Vactra 2 way oil and Mobil DTE26 hydraulic oil in the headstock Rakker
  17. #13
    Sep 2007
    Spanish Springs, NV
    2,365
    155
    292
    It's been years ago so I looked and found the business I bought from in San Jose is no more.
    This link will find dealers for you in drum size, they deliver in my experience. Try the "where to buy" in this link. Good luck!
    Industrial Lubricants, Oil & Grease | Mobil™ Industrial Lubricants
  18. #14
    Sep 2007
    Spanish Springs, NV
    2,365
    155
    292
    "I'm running Mobil Vactra 2 way oil and Mobil DTE26 hydraulic oil in the headstock Rakker"
    You can do that of course but do you know that is not what should be in a Monarch headstock? Do you know why it shouldn't be there?
  19. #15
    May 2010
    Palo Alto
    52
    12
    21
    Quote Originally Posted by DaveE907 View Post
    Not only would I like to know why it shouldn't be there but what should be there.
  20. #16
    Oct 2012
    Virginia
    10,264
    5843
    4629
    Start at post number one, roll forward.
    "Vactra Heavy Medium" is now labeled as "DTE Heavy Medium". Same intended use.
    Formula may have changed. Or not.
    'Improved' or otherwise, that wudda been done by experts mindful of the needs.
    "Why NOT <any of several incorrect choices>" and WHY they are incorrect?
    Covered on PM also. Wants more reading. If it is worth it to a body.
    Too many possible flavours of 'wrong' for me to overmuch care.
    Unless they are wickedly good FUN, anyway.
    Bill
  21. #17
    May 2010
    Palo Alto
    52
    12
    21
    Bill
    Pos #1 you say? That'd be my post Yep so I'm going with DTE Heavy Medium. Vactra 2 for the saddle and ways.
  22. #18
    Oct 2012
    Virginia
    10,264
    5843
    4629
    Soitenly... You opened the thread by saying "the manual calls for...".
    Good move, that.
    All after was but 'recall' of prior investigation and vetting of cross-ref to present-day Exxon/Mobil nomenclature.
    Bill
  23. #19
    Sep 2013
    Oregon
    80
    123
    35
    mmmmmm, nope.
  24. #20
    Jul 2011
    Utah
    976
    2137
    400
    I want to know the answer!
    Is it the particles-kept-in-suspension issue?
    Like, does the DTE numbered series work for filtered oil systems, whereas the letter series DTE oils don't have the detergents that carry particles...just lets them fall to the bottom?
