lectrician1
Hot Rolled
- Mar 6, 2012
- Las Vegas
To remove the site glasses, I take the three 8-32 screws out, then I get three 10-32 socket head screws 1" long and screw them into the soft aluminum bezel. they cut their own thread in the aluminum. as soon as the larger screw hits the cast iron it pushes the bezel right out. Then I remove the cork and back plate and cut a relief in the back of the bezel for a rubber o ring #215 available at home depot. Clean the bezel and the plastic lens and reinstall with the original 8-32 screws without the cork and backplate. No leaks o rings work great.
