I am in the general process of partial disassembly of my 10EE for cleanup and painting. Like others before me, I didn't plan on such a complex disassembly, but it got away from me especially after looking at the superb work of others.
I have had (with the exception of one) no problems removing taper pins and the lathe is generally disassmbled into its assemblies. The the taper pin is out on the tumbler lever (I myself call this the 'feed engagement' lever). So it would seem the lever should slide-off to the right but it won't budge and I have applied what I consider the maximum advisable force on it. I did this by engaging the shaft end with what amounts to a gear-puller to assist in yanking. I have also tried heating. Am I missing something?
Back to my single disobedient taper pin. The 'back gear' lever has a pin which has been man-handled in the past and the small end is non-existent (it had been smashed flush with the OD of the lever). It is now literally is not visible. I removed paint and then tried polishing the area to see if I could highlight the location of the small end of the pin but this actually made it worse. Invisible.
Does anyone have an ingenious technique, besides destructive disassembly. I saw Cal's trick with the ball bearing, which I would be happy to try but I can't locate the position.
