Replacing 10EE leadscrew reverse shifter packing?
Likes Likes:  0
Results 1 to 5 of 5
    Jul 2018
    North Carolina
    114
    36
    Default Replacing 10EE leadscrew reverse shifter packing?
    My 1942 10EE uses string packing around the shaft that engages the reverse clutch rack. Has anyone ever just replaced it with a stack of modern O-rings? The shaft is .750" and the hole for the packing is ~15/16", which works out nicely for a standard 3/32" O-ring.
    Virginia
    16,233
    7561
    10820
    Quote Originally Posted by focusrsh View Post
    Can't see the harm. Any machine tool as doesn't weep a bit of lube is probably empty of it!
    "O" rings can be selected for compatibility with the lubes used.
    Even so, both Graphite-impregnated and Teflon-impregnated "string" stem or bonnet packing materials are still out there - close as the plumbing supply wall-hanger blister packs, any "Big Box" store. There are still a few plumbing goods as use the stuff at least w/r "old work" repairs.
    Mar 2002
    dallas,tx
    2,584
    659
    516
    I found if the dimensions are suitable, to replace that kind of old tech with press -in single lipped oil seals. But if not, a o -ring is a good substitute.
    Jun 2007
    Nevada
    590
    82
    Mcmaster has all different packing strings. The hole you refer to is threaded and I was concerned o-rings wouldn't seal on the threads so I used packing from Mcmaster.
    Virginia
    16,233
    7561
    10820
    Quote Originally Posted by bll230 View Post
    Packing retention may not be the ONLY reason it was threaded, but yazz. That suits.
