Replacing old elec.stuff
Likes Likes:  0
Results 1 to 5 of 5
    Mar 2002
    dallas,tx
    2,577
    623
    505
    Does anybody have a knowledgeable electronic
    supplier that has or can find the obsolete
    components in the 50's and 60's EEs. The oil-filled capacitors are first thing on the list. Thanks
    Sep 2002
    Rochester, NY USA
    696
    Hi Daryl:
    Those oil filled bathtub capacitors are ultra expensive. You can buy ones at half rating and wire them parallel (Piggyback). They were originally MilSpec and very expensive. Try Empire Machinery 585-328-2340. they've got a set laying on their bench right now that work and are used.
    Steve
    Feb 2002
    Peralta, NM USA
    5,830
    54
    548
    The mica caps are easy enough to find, as well as the single caps. But the duplex .25 mfd I couldn't find in anything near the same form factor. I would go around replacing anything that isn't at least suspected - if it's lasted 45 years it's likely to last another 10 or so.
    J Tiers Guest
    The capacitors don't really have a "wear-out" mechanism. They are good until they break down and leak, or go open.
    Unless proven bad, leave them alone, you have nice life-tested parts!
    Mar 2002
    dallas,tx
    2,577
    623
    505
    were going to give them a thorough test,and hopefully put them back into service, but I
    like to keep them bases covered. Have sent them to a specialty capacitor co. in NY. If they come up with viable replacements, I'll post the results here.
