Request for pictures of a 10ee properly secured to a trailer.
Results 1 to 18 of 18
    Sep 2015
    204
    13
    146
    Default Request for pictures of a 10ee properly secured to a trailer.
    I'm going to help a friend move a 10ee this week. We've searched the forum and YouTube and found lots of information on lifting and moving them around, but very little on securing one to a trailer. If anyone has pictures or other info on the way to do this properly, I'd greatly appreciate seeing them
    Thanks.
    Jerry
    Sent from my Nokia 7.1 using Tapatalk
    Jun 2006
    1,230
    1207
    194
    Quote Originally Posted by jerholz View Post
    Thanks.
    Jerry
    Not really enough information.
    Trailer type?
    What are you fastening straps/chains to?Generally do straps pulling in opposition.
    I would use rags under straps or chains to prevent marking/scraping.
    Here’s my 10EE when it arrived on a conestoga truck, with chain binders:
    Another view:
    Sep 2015
    204
    13
    146
    Thanks for those. It's going to be a drop bed from Sunbelt. We have a few options on what to secure it with. Just trying to see what works.
    Jun 2006
    1,230
    1207
    194
    Heavy ratchet straps are relatively inexpensive.
    https://www.homedepot.com/p/27-ft-x-...0903/312969420
    Drop deck trailers are great for moving lighter machines like the 10EE and Bridgeports/knee mills.
    Sep 2009
    Apex, NC
    1,765
    893
    I've used rollback wreckers to move bridgeport, hardinge lathe, Milltronics VMC, overhad sander, etc. Just need to bolt machine on skids or heavy pallet usable with a pallet jack, pick it up an inch with a pallet-jack, use the heavyduty winch on the wrecker to pull it up. Reverse process for offloading. The nice thing about that process is you never have to pick the machine up over an inch. The rollback wreckers are also handy because they can adjust to varied dock and trailer heights, have proper holddowns, etc. The bed can extend right into a garage door. Just need to be aware of the center-of-gravity position for the tilt of the trailer (e.g. lathe parallel to the bed, and headstock to the cab). $100-150 is well worth it.
  6. Likes rpseguin liked this post
    Jul 2018
    New Hampshire
    138
    25
    You should secure all of the doors. Some are not on hinges and could fall
    off and be lost. Be sure to clamp the tail stock. Also you want to use
    a tarp in case of rain or just general road dirt.
  8. Likes rpseguin liked this post
  9. #7
    Nov 2020
    Ohio
    98
    6
    15
    Here is mine on a no ramp trailer from sunbelt. I also made sure to take the back covers and tailstock off and put them in the truck bed. Also make sure to charge the battery. Those little solar panels don’t seem to charge them enough.
    For strapping the lathe down I just used all the D-rings / cut outs and strapped it under the bed. Might have gone a bit over kill on the straps but it’d rather have more straps than a 10ee sitting on the side of the road. I really really like the Home Depot ratchet straps and they are only about $8 each. I also locked the carriage and strapped it to the bed. Make sure to secure anything that has the possibility of moving around and take everything off that you can.
    I loaded this one with a pallet jack and harbor freight come alongs. I took the trailer off the truck and lowered it as far as possible and winched it up the ramp. I put a 1/4” piece of metal plate on the front forks of the pallet jack to stabilize it and ratchet strapped it to the pallet jack. Worked very well and I have since used this same method for other machines.
  10. #8
    Mar 2021
    43
    79
    16
    Here is how I did mine. Drove it home 430 miles away. I checked the straps in gradual increments. First few miles, then about half hour, then hour, then couple hours.
    Make sure you have it sitting on wood, no steel on steel.
  11. #9
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,262
    466
    1130
    I was a little paranoid, it was the most expensive machine I had bought to that point...so....
    I took off the end covers and wrapped them in movers blankets. I removed the C16Js and bubble wrapped them.
    Moved using the Uhaul "RO" double axle open trailer, ~600 miles.
    The machine is bolted to 4x6 timbers cut close to the trailer width to prevent side-shifting. Bolted to timbers using the leveling-foot thru holes in the casting. Various other timbers to prevent it from sliding forward in case of hard braking. The chain under the headstock I believe is cushioned by some old bathmats. I believe there's also a 1" ratchet strap wrapped around the tailstock base so it can't unexpectedly slide off.
    The tarp is to prevent rain (and on the next move, road salt spray I was not anticipating). Just used a 1" ratchet strap like a belt.
    Lifted out nice and easy with the gantry.
    Collet nose, collet tube, chucks, tool post all went in the cage with me.
  12. Likes 220swift liked this post
  13. #10
    Oct 2004
    Montana
    1,221
    170
    82
    Matt looks like you did a great job.
    Hal
  14. Likes matt_isserstedt liked this post
  15. #11
    Jun 2020
    Minnesota
    98
    45
    53
    No pictures and not a 10EE.
    I hauled both a Monarch 12 CK and a 15"x42 Leblond Dual Drive on one trailer load. I used 6x6 wood blocks on top/ between the ways and 2 chains and binders on each machine - one forward, one aft. Bound them down Hard with a 3' cheater pipe.
    Piece of cake.
  16. #12
    Sep 2015
    204
    13
    146
    Thanks all. We're going to get it tomorrow. I'll take some pictures.
    Jerry
  17. #13
    Sep 2015
    204
    13
    146
    Well, made it to the floor of his garage. It's still on the pallet. Here's how we did it.
    Seller was a pretty capable rigger. Sunbelt didn't have the drop trailer.
  18. #14
    Sep 2015
    204
    13
    146
    While we were there, I bought a Wells bandsaw. It's a little rough but I got it pretty cheap.
  19. #15
    Sep 2015
    204
    13
    146
    So, this is Pharme's lathe. I'll try to talk him into starting his own thread on it with more pictures. It needs at least one of the big tubes, and I'm sure he'll have lots of questions for the group.
  20. #16
    Sep 2015
    204
    13
    146
    Couldn't resist a few more.
  21. #17
    Sep 2015
    204
    13
    146
    One more.
  22. #18
    Dec 2017
    ALAND ISLANDS
    98
    9
    37
