Restoring 10EE 1954 vintage - Page 18
Page 18 of 18 FirstFirst ... 8161718
Results 341 to 343 of 343
  1. #341
    Oct 2014
    Maryland
    113
    9
  2. #342
    Feb 2002
    Peralta, NM USA
    5,661
    49
    473
    That oil line is the headstock oil overflow.
  3. #343
    Sep 2002
    Arizona
    3,631
    828
    484
    Quote Originally Posted by MachinistBlue View Post
    That line is the overflow for the center reservoir. You're looking at the fitting that threads into a tapped hole in the left/back corner of the headstock. If you take the top cover off and look in the left rear corner, you can find the drain hole, which should be just above the oil level. The other end of the line is routed to the flat tray that's cast into the top of the base, above the motor compartment.
    I can't help you regarding tapping holes for the closer, but I can tell you that you won't hit the oil line. Call Scott at Monarch and see if he can give you any guidance.
    Cal
