TravisR100
Cast Iron
- Aug 7, 2006
- Houston, TX
I’ve never seen a gib on a half nut but hey, something new every day. When I got the lathe, as I was cleaning it, I found a piece of cast iron down in the base that appeared to mate with a dovetail. I figured it was from some piece of work done on the machine previously. No. Not so lucky. It was apparently half of the gib on the half nut mechanism.
If you look closely in this picture you’ll see the below the lead screw the gib is intact. Above, it’s missing and the shafts of the screws that were sheared off are still there. Luckily those screws were loose and easily removed.
The screw in the middle above is the head of the screw/bolt you can see at the bottom of the first picture. Not sure how any force acted on this to do this damage. The other two fragments are the remains of the other screws. Luckily I kept the piece I found in the bottom of the lathe.
Above you see the piece that was still bolted on and the piece I found in the bottom of the machine. They are obviously cast iron. With the forces as they are on this part I plan to just JB weld the two pieces together.
Sent from my iPad using Tapatalk
