TravisR100
Cast Iron
- Aug 7, 2006
- Houston, TX
Does anyone know what it is? The manual says the first back gear is 22 to 200 and second back gear is 44 to 400. But it doesn’t give the open belt speed ranges. Tony’s site says the back gear ratios are 6.25:1 and 12.5:1. If that’s true then the max speed would be 2500 RPM. He also says the motor is a 1750 RPM motor. My motor data plate says 3470 RPM max 500 RPM min.
I also found the dedicated rivettlathes.com that says speed range is 22 to 3600 RPM and the motor is 1750 RPM.
