Rivett 1020s - Max spindle speed
Likes Likes:  0
Results 1 to 9 of 9
    Aug 2006
    462
    9
    112
    Default Rivett 1020s - Max spindle speed
    Does anyone know what it is? The manual says the first back gear is 22 to 200 and second back gear is 44 to 400. But it doesn’t give the open belt speed ranges. Tony’s site says the back gear ratios are 6.25:1 and 12.5:1. If that’s true then the max speed would be 2500 RPM. He also says the motor is a 1750 RPM motor. My motor data plate says 3470 RPM max 500 RPM min.
    I also found the dedicated rivettlathes.com that says speed range is 22 to 3600 RPM and the motor is 1750 RPM.
    Virginia
    16,110
    7561
    10756
    Quote Originally Posted by TravisR100 View Post
    What's your tachometer marked to?
    Aug 2006
    462
    9
    112
    Thinking about this further, at the middle speed of the Reeves drive the ratio would be 1:1 and therefore 1800 RPM.
    If the speed ranges of the two back gears are 22:200 or 44:400 that is 9:1 basically. So the ratio range of the reeves has to be 9:1. If the max RPM is indeed 3600 then the output of the reeves must be 400 to 3600. That sound correct?
    Virginia
    16,110
    7561
    10756
    Sounds too complicated.
    What's the top-end marking on the tachometer? Marking should tell the tale even if it is not working.
    Aug 2006
    462
    9
    112
    Not near the lathe at the moment to look.
    May 2003
    5,191
    21
    581
    I saw the motor, being a dual mount type its certainly not original, 3600rpm, perhaps the source of your hum, high speed AC motors not so good for heavy starting loads like lathes.
    Virginia
    16,110
    7561
    10756
    No need. You are here.
    Understanding the Rivett 1020/1030 Tachometer
    There are more.
    Sounds as if design was for 4,000 RPM.
    The target they meant to compete with - "standard" 10EE - were 4,000 RPM already, special-order 6,000 RPM - maybe even 8,000.
    As to the motor RPM.. as just pointed out, that's only a "two-pole". More common on a grinder / buffer / polisher for light loading than on a lathe or mill.
    On-edit:
    PM does have a few threads on rebuilding Worthington's drives, but so far, other makes or models.
    Meanwhile:
    Worthington Allspeed Drives: Instantaneous Variable Speed Control - Worthington Pump and Machinery Corporation - Google Books
    May 2003
    5,191
    21
    581
    Information here regarding the machine, drawings of the drive begin on page 28, apparently the motor was either 3 or 5hp, and 22 to 3600 rpm spindle speed.
    The variable speed reeves type drive said to be made by Worthington pump and machinery corporation, Rivett directing drive parts to be ordered from Worthington. I suspect the Moore jigbore drives made by the same company.
    The publication has no date. I would expect correct adjustment procedures to be in the operators manual.
    http://www.vintagemachinery.org/pubs/2379/20326.pdf
    http://www.vintagemachinery.org/pubs/2379/4492.pdf
    Dec 2004
    MA
    113
    26
    35
    On the build sheet order form you could select either 2500 rpm or 4000 rpm.
