Rivett 1020S - Video and electrical hum question - Page 4
Page 4 of 4 FirstFirst ... 234
Results 61 to 79 of 79
  1. #61
    Jan 2017
    Washington
    247
    61
    Quote Originally Posted by TravisR100 View Post
    You say they might have missed the wiring of the reeves motor. Missed what? From what I can tell that motor just uses two of the 3 legs. It works at any rate however the function of the slow/fast buttons is reversed.
    I am too late to the forum -- I'm not the best at checking it super often. Sorry. I'm glad you found the source of the hum.
    On the reeves control motor --> If they got the power legs got hooked up backwards when the voltage was changed over, then the motor could run in reverse. Not saying that's the cause, but it could be.
    As far as my comment on missing the wiring, I was meaning that someone might have overlooked the wiring to the control motor. When they convert the voltage, they may not have moved the wires for the control motor to the 'new' 220v legs of the motor or wired it up wrong but that's a moot point because the motor is working and it sounds like you checked this already. I missed that part, sorry.
  2. #62
    Jan 2017
    Washington
    247
    61
    And I'm stealing your idea for the light in the undercarriage - thanks for the photo!!
  3. #63
    Aug 2006
    406
    9
    87
    Quote Originally Posted by medsar View Post
    Got it. Thank you for replying.
  4. #64
    Aug 2006
    406
    9
    87
    I now know what “pretty expensive” means for a replacement brake. $1,900.
  5. #65
    Aug 2006
    406
    9
    87
    Talked to an engineer at Dings who listened to the video. He thinks it’s just a voltage drop on startup. Will follow up when I get my fluke meter back.
  6. #66
    Aug 2006
    406
    9
    87
    Do you happen to recall the size of the motor shaft where the brake connects?
  7. #67
    Virginia
    27,322
    7561
    8516
    Measure it. Can't repair or replace it without removal in any case.
  8. #68
    Mar 2013
    Oklahoma, USA
    19
    6
    Quote Originally Posted by rustytool View Post
    Is that on original Rivett turret ?
    Or something adapted?
    Nicest 1020S I've ever seen. And a late model S with the exposed headstock bolts so you don't have to remove the gearbox to get the headstock off.
    I believe the machine was originally sold with the turret. There is a little triangle badge on the front panel of the machine that says Nuetzel Machinery Company, St. Louis. At some point this company relocated to Kansas City. When I investigated it a little further, I found they sold Rivett turret lathes and press brakes among other things. Apparently, there was some type of press brake accident. There was a lawsuit and the company closed a short while later. I don’t know how many of these machines they sold. I found mine near Kansas City.
  9. Likes rustytool liked this post
  10. #69
    Mar 2013
    Oklahoma, USA
    19
    6
    Sorry, I don't recall the size. Seems like it was around an inch - best guess.
  11. #70
    Dec 2003
    Calgary, Alberta, Canada
    1,419
    9
    97
    Keith Rucker on you tube just bought a 10-20s, it has way, way more bed wear than yours.
  12. #71
    Aug 2006
    406
    9
    87
    Quote Originally Posted by quasi View Post
    Yep, I saw that when he posted it.
    Sent from my iPad using Tapatalk
  13. #72
    Aug 2006
    406
    9
    87
    For anyone wanting to see the brake actuating...
    YouTube
  14. #73
    Virginia
    27,322
    7561
    8516
    YouTube
    OUCH!
    I'd shed that sumbich in a New York Minute ... on general principles!
    My HBX-360 has a foot-treadle, linkage, external band brake. Looks like a Vee-belt pulley and a cut-off section of belt, one end anchored, the other wrapped and tightened. Or not. All mechanical.
    Newer HBX, electro-hydraulic, and disk type.
    Airhart & Sputniks sell a ton of the basic goods, mechanical, air, hydraulic, electric. ATV, RV, agro, groundskeeping market, mainly, for quite reasonable prices. Or buy the caliper and fab a rotor?
    At the very least? I'd want to operate off DC to get shed of that 60 Hz growl. Auto-air-con compressor clutch, the example of how much less noise that can produce. So long as .. the DC is filtered, anyway.
  15. #74
    Aug 2006
    406
    9
    87
    Well, it’s been a while and I thought I’d give an update on this thread since I made a step forward, but not really.
    I knew the noise was coming from the brake. I started looking on eBay and found that someone had the exact model Dings brake that I needed. It was an R71015, 3 phase. It was still more than I was willing to pay at $400. I watched it sit there for about 4 weeks and finally offered $150 for it. Instantly accepted. Think I offered too much. Anyhow, it showed up yesterday.
    I opened it up this evening and was surprised to see that it is obviously new old stock. Brand spanking new. Here are some pics.
    A few things I noted. The rotating friction disk on the new one is much thicker. Obviously the old one was worn. The torque springs on the new one are adjusted for more torque. Someone had apparently reduced the torque on the old one. The old one was missing the shafts for the manual brake release.
    Once I got the old brake off I started the lathe with no brake. No noise! Positively figured out that the noise on startup was coming from the brake, not the lathe motor.
    Wrestled the new brake into place, mounted everything, wired it up, crossed my fingers it would work. It works, but it makes the same exact noise on startup. . At this point I’m thinking it has to be something electrical but just not sure what.
    On the positive side, the lathe now has a brand new brake. And it stops much quicker than the old one did.
  16. Likes rustytool, Cal Haines liked this post
  17. #75
    Aug 2006
    406
    9
    87
    Default Rivett 1020S - Video and electrical hum question
    I’ve done some more checking on the electrical. I measured the voltage coming into the machine and also going out to the motor/brake.
    Coming into the machine...
    L1 to L2
    247 machine off
    235 running
    157 on startup for less than a second
    L1 to L3
    247 machine off
    234 running
    161 on startup
    L2 to L3
    243 machine off
    241 running
    223 on startup
    L1 is the manufactured leg.
    Leads going to the motor while running are the same as the running numbers above.
    I took my first cuts with it. I’m also noticing that in open belt the motor seems to bog down with a .040” cut.
  18. #76
    Aug 2006
    406
    9
    87
    I had started another thread about what seemed to be an issue with the motor bogging down. Just an FYI, this turned out not to be a problem with the motor at all. The varidrive belt was slipping because it had oil on it. What definitely sounded to be the motor bogging down was just the sound of the entire drive train slowing down.
  19. #77
    Nov 2004
    Webster Groves, MO
    7,271
    1826
    3318
    Bed won't show much wear on any of the long-carriage "Grand-Old" Toolroom / Tool & Gage lathes.
    It accumulates on the underside of the softer CI carriage.
    To avoid being obligated to sacrificing TWO goats for your great good fortune..
    ... see what moves if you lighten-up on the carriage hold-downs (ball-bearing ones on my 10EE's), then check by alternating about 100 lbs of sandbag to each corner or "wing" in turn. There's usually some "rocking horse" movement. Even so.. it may not be enough to bother your work.
    ...if not.... about that sacrificial goat?
    Step-by-Step Guide to the Perfect Argentine Asado
    Where do you find it? Not in Mexico. The only time I saw cabrito asada on a menu was in Neuvo Larado and it wasn't lunch time. I looked for it from Brownsville to Panahachel, Guatemala and never found it again.
    Bill
  20. #78
    Dec 2005
    calif
    216
    I worked as a maintenance mechanic for 36 years. Our factory had people that did electrical work. I'm not a electrician. I have heard that noise or similar. My electrical partner said, that noise if from the contactor bouncing, not closing all the way. It had to do with a bad shading coil. we changed the contactor and the noise went away. If you can find the contactor that operates the motor. If there is a way to hold the contactor down when you start the motor. See if the noise goes away. There are things in life that can hurt you. Doing this is one of them. Stan
  21. #79
    Dec 2005
    calif
    216
    Looks like you found the problem. I should have read further down. Stan
