medsar
Cast Iron
- Jan 13, 2017
- Washington, USA
I recently purchased a Rivett 1030F and I am working on getting all the kinks worked out. It was originally wired for 220v 3 phase from the factory and was converted to 440 3Ph at some point in its life. I bought the machine with a 15kva 220->440 3Ph transformer. Unfortunately, the transformer has a ground fault in it. I have a 10hp RPC that supplies 220v 3Ph and the machine has a 5hp motor. I am at a crossroads -- I can either buy another transformer (probably a 6kva or 9kva) and spend a decent amount of money or I can convert the lathe back to 220v 3Ph. I have checked the wiring specs from the wiring diagram from Rivett along with the actual wires in the machine and they are capable of handling 220v amperage. Changing the voltage on the motor is the hardest part. It would require moving the motor/clutch skid partially out of the machine because the motor wiring box is exactly in the wrong place (hidden behind the support column). I think it would require making a special pair of skates to move the skid a few inches to get access to that wiring box. If anyone who has removed the motor out of a 1020 or 1030 has any suggestions or better ideas, please let me know.
This begs the question --> Is it worth it to convert it back to 220v 3Ph or should I just spend the green to buy a new step up transformer?
