For a Round Dial 10EE, Serial 26080
Can someone/someones please help me identify which shafts in diagram E-4 (Gearbox) are the shafts visible on the apron side of the gearbox. I am trying to put together a full bearings list and want to have all the correct terminology.
Apron side of gearbox
As far as I know, Shaft 1 is the leadscrew, which is oddly shown at the bottom of diagram E-4 and is shaft 91.
I would prefer not to guess on the rest although logic would dictate shaft 3 as the feed rod, shaft 2 as the cone gears and shaft 4 as the change gears, based on the orientation on the other side of the gearbox.
I am trying to correctly (meaning, with the proper terminology) define the bearings that belong on the shafts with part #'s
33,54,76 and 91 on the Gearbox diagram E-4.
#2,3,4 in the posted image all use the same New Departure 3204 bearing, at least that is what is in this gearbox currently.
#1 Uses a New Departure N20205, best I could find was an angular contact N20205. Is that bearing an angular contact bearing?
