Series 61 (1957) partial feed and threading problem
Results 1 to 5 of 5
    Feb 2010
    Illinois, USA
    656
    29
    190
    Default Series 61 (1957) partial feed and threading problem
    My Monarch Series 61 toolroom lathe has a partial problem with feeds and threading. The lathe has the AB and CDE selector levers. Everything works just fine for threading and feeding when the AB is combined with either the C or D range of feeds and TPI. Problem is, when either is combined with the E range, which just so happens to be the most popular range of feeds (approx. .010 to .020) and TPI (6 to 16)that I would use. I don't thread often, but now I've got to do some 12 tpi threading, and I need to repair this.
    Any guidance pointing me in the right direction of where to start figuring this out is appreciated. Something in the gearbox in the E range is not working/connecting.
    Thanks for any help.
    Jul 2004
    Houston, TX USA
    29,641
    May or may not be related. My August '46 CW 16 "E" position OFTEN does not want to engage all the way - I have to lean on that lever until feed rod is turning
    I would imagine this is related to a dirty dog clutch
  3. Likes Cal Haines liked this post
    Feb 2010
    Illinois, USA
    656
    29
    190
    John,
    That was it! I pushed the CDE lever all the way past the "E" pretty hard, while free spinning the chuck with my right hand, and it engaged. Everything working now. Thank you. I would not have known to try that.
    Any idea what a proper solution is to this problem? Sooner or later, my guess is it's going to get worse. The manual on this lathe, from Monarch, does not discuss these remedies at all.
    Aug 2012
    California, Central Coast
    3,416
    2168
    1330
    Quote Originally Posted by johnoder View Post
    Quote Originally Posted by hawkfan9 View Post
    John,
    Could it be a dirty or gummed up mechanism that needs 60+ yrs of grime cleaned out?
    Feb 2010
    Illinois, USA
    656
    29
    190
    I guess it sure could be. In order to get to the gear box on this lathe, the front cover has to come off, along with the side cover.
    Has anybody been inside one of these to know if there are any precautions, flying spring loaded mechanisms, etc....to be aware of in removing these covers. I have, both, the owners operator manual and the parts manual from Monarch. Neither discusses disassembly at all. Before I take it apart and attempt a repair/cleaning, I'd like to hear from someone who has been in there.
