Series 62 Jogger function
Likes Likes:  0
Results 1 to 5 of 5
    Nov 2009
    Waller, TX
    76
    11
    Default Series 62 Jogger function
    I'm trying to determine the jogger function on the series 62 lathe. The hydraulic shifting works reasonably well, but in the operations manual it clearly states that the jogger can be used to indicate a part. Well mine doesn't really rotate the spindle, just basically a bump to get the gearing to line up for a speed change. Sometimes, a quick pull on the chuck helps it along.
    If anyone with first hand knowledge of the jogger on a series 62 can describe what it should be doing, I'd appreciate it. If not, I'll give Monarch a ring.
    Dave
    Oct 2006
    Woodland Hills, Ca. and some times Hutchinson, Ks.
    2,299
    16
    582
    On my 2013 lifting the handle jogs the spindle, I don't have the manual here sounds like a linkage adjustment?
    Steve
    Nov 2009
    Waller, TX
    76
    11
    Many thanks Steve, that's what I was trying to find out. I really don't get a rotation, so I'll do some digging.
    The manual has you go through about 4 of the hydraulic valves first, so I'll start there. Then pop the headstock cover and see what's inside.
    Mine's a 2516, 1969 vintage. Big girl for sure.
    Dave
    Aug 2006
    Shelbyville, Ky
    497
    44
    182
    On my series 90 holding the clutch lever up operates the jog function. It is a very distinct audible click and ratchet of the chuck. It does also operate when shifting to help the headstock get into the gear selected.
    Nov 2009
    Waller, TX
    76
    11
    A brief update.
    All the hydraulics checked out, which is what I thought since it was thumping. Removed the entire rear hydraulics panel to expose the jog clutch itself. Removed it, looked fine. then removed the jog clutch body and had all four roll pins and all four retaining screws sheared in the end of the input shaft. This required complete removal of the main input shaft, which required the clutch/brake assembly to be removed.
    Now to remove the pins and broken screw from the end of the shaft.
    We'll see if Monarch has any parts available, and get it back together.
    Dave
