Square dial compound question
Results 1 to 7 of 7
    Jun 2007
    Nevada
    571
    77
    Default Square dial compound question
    I was setting my compound to 0 degrees, and I noticed it wasn't. Upon further inspection the degree markings are about 3 degrees off square, so to speak. Is the degree wheel a separate part from the compound base? I had thought the degree circle was integral with the compound base, but if so that would mean Monarch really messed up that part when they made it. In the picture the black mark is exactly in the center of the base, and the 90 should be symmetrical on the mark. Before I started pressing on things I thought I would get other opinions.
    If Monarch did mess up the degress that much it would have been an egregious manufacturing error.
    Mar 2002
    dallas,tx
    2,578
    625
    505
    Ok, put it all back together and then measure if it is off with the hashmark on the crosslide. Where the graduations are to where your black mark is, is not where it is important. Remember one side of the compound dovetail has a gib, so that dovetail is offset to accommodate that. It looks like the graduations are done to accommodate that offset. Put the compound on '0' and then run a dial indicator down the side as you move the crosslide in, and the compound should be "square" with the centerline of the spindle. Usually there is a slight inward bias of the crosslide a few tenths over the entire travel, so that when facing off a round, it cuts a slight concave so the round sits flat. Unfortunately, looks like you have a bit of damage to the graduations. Also, it is not unheard of that certain components (like a compound screwed up in a crash) are not necessarily original to the machine. If all of this is off, then you will have to make new hashmark. I had to to this, as I completely reground, rescraped all of these components, and was able re-engrave the hashmark to be spot on. On mine, the compound graduations go all the way around,so you can put hash marks on both sides of the crosslide.
  3. Likes Colt45 liked this post
    Jun 2007
    Nevada
    571
    77
    Daryl, I am going with your thought that the compound was replaced. Maybe Monarch wasn't concerned whether the degrees were perfect and scribed the marks on the cross feed to match the compound. I have a mark on both sides of the cross slide as well as the front. I can line up 0 degrees, -90, and +90 perfectly on the marks, but the compound is not square. I'll just add 2 1/2 degrees to my settings until I can scribe new marks.
    Thanks - I have a 16 DP hob coming and will have your 60/57 made sometime this week or next.
  5. Likes daryl bane liked this post
  6. #4
    Mar 2002
    dallas,tx
    2,578
    625
    505
    Ya know....since your graduations are all damaged. You could turn those off and make a new slip-on ring with the graduations (dust off that ole dividing head ) and a setscrew. Dial it all up and then move the new graduation ring to perfection. Just a thought.
  7. #5
    May 2003
    4,956
    13
    543
    It would be hard to believe the marks were off from the factory. There are many parts that are hand fit, and some like levers that were hand drilled for taper pins, so they usually wont line up on another machine.
    On the other side is the Atlas lathe, where I don't think anything was hand fit.
  8. #6
    Mar 2002
    dallas,tx
    2,578
    625
    505
    I went and eyeballed my compound and it is dang near identical to bll230's pic. The 90 is just shy to the left a couple of degrees. So obviously it is intentional. So something else is amiss.
  9. #7
    Jun 2007
    Nevada
    571
    77
    Again, I asked Steve at Monarch this question. Saves a lot of time to ask the source...
    He explained that the witness marks were put on after assembly on each lathe, and that when swapping cross slides or compound bases the marks will probably not line up. Daryl's judgment was right, I likely have a non-original compound base. When I take the lathe aprt to install new Bijur fittings I will scribe new witness marks.
  10. Likes daryl bane, Zap921, old_dave liked this post
