Strange slow fail on my Modular - Page 2
Results 21 to 40 of 55
  1. #21
    Dec 2012
    northwestdioxide northwest
    81
    14
    280 out of gear
    56 in gear
    I thought those were the leads you were talking about but I just wanted to make sure.
  2. #22
    Dec 2012
    81
    14
    Quote Originally Posted by mllud22 View Post
    Check through pages 10 through 19. Its a pdf file of the manual. The electrical section is pretty good.
    http://www.vintagemachinery.org/pubs/2103/3423.pdf
    Few minute's to download 59 pages
    Thanks for the Download,I've got the manual from Monarch for my machine but having an ecopy is great.
  3. #23
    Mar 2016
    Louisiana
    483
    237
    87
    Quote Originally Posted by Drstrangelove View Post
    280 out of gear
    56 in gear
    You will need to find what is loading that circuit down when in gear. Check the primary of t4 when in gear and see if it is 240 VAC
  4. #24
    Dec 2012
    81
    14
    Quote Originally Posted by labeeman View Post
    So the primary of T4 (33 and 66) is 125VAC both in and out of gear. That checks with points 1 and 2 which is the control voltage.
  5. #25
    Mar 2016
    Louisiana
    483
    237
    87
    OK something is loading the output of T4 when it is in gear T4 is a constant voltage transformer cant be to constant if it changes to 55 volts when in gear versus not in gear. Check the field voltage on the spindle motor when in gear and not in gear it should be 100+ dc at the lowest speed setting lets see if that is working.
  6. #26
    Dec 2012
    81
    14
    Ok so I realized that I had disconnected the incorrect leads this morning and rechecked the T4 secondary voltage with 47 and 48 disconnected. Same outcome, T4 secondary low, 56 ish volts but the lathe momentarily spun up at full acceleration before the QSD kicked in and stopped it.
    Measuring from pin S1 to S2 on the terminal strip below the main contactor I got 0VDC out of gear and 70MVdc in gear.
  7. #27
    Mar 2016
    Louisiana
    483
    237
    87
    Nope F1 F2 shunt field is what I need for you to check.
    Delta is going to visit me tomorrow and I may not be able to communicate for some time.
  8. #28
    Dec 2012
    81
    14
    128VDC out of gear
    74VDC in gear
    I have to have the speed knob turned up to about 1/4 speed to get the spindle to rotate.
  9. #29
    Mar 2016
    Louisiana
    483
    237
    87
    128VDC out of gear
    74VDC in gear
    You do not need the spindle to rotate. You need to find why the reference circuit is dropping down so much when you engage the spindle fix that and your problems will go away. I suspect you have a chip that has shorted something I would take the modular out and blow it out you have a short you need to find. It sounds like it went away for a second for you.
  10. #30
    Dec 2012
    81
    14
    Good to see you back.
    I'll do that today, I've had the modular cover off a few times checking voltages but I'll give it a blow off.
    I'll also recheck the shunt field voltage at slow speed.
    The full speed acceleration I saw was due to the control or grid lead's being disconnected from the SCR's. With those disconnected the speed control and the constant voltage transformer voltage aren't part of the functional circuit. I spent a lot of time looking at the schematic after that and understand a tiny bit more how this thing functions. Digging back to high school electronics and the little bit of tube experience I have building a guitar amp. Still way over my head though.
    I appreciate your help!
  11. #31
    Dec 2012
    81
    14
    Ok, finally got out to the shop.
    It shows 125VDC across F1-F2 at slow speed position on the speed knob.
    Blew out the Module and no change.
  12. #32
    Mar 2016
    Louisiana
    483
    237
    87
    That is correct it should only go down when the pot is at half turn.
  13. #33
    Dec 2012
    81
    14
    Ok, I checked that and that is what happens. 125VDC until about half rotation of the speed knob then the field voltage starts to drop off.
  14. #34
    Mar 2016
    Louisiana
    483
    237
    87
    Is your reference voltage still dropping voltage when engaging the spindle? Your field voltage circuit is working fine now.
  15. #35
    Dec 2012
    81
    14
    Yes reference voltage is 280 out of gear and about 55VAC in gear. I tried it with the speed knob all the way slow which typically has no spindle motion and still 55VAC.
  16. #36
    Mar 2016
    Louisiana
    483
    237
    87
    You have something loading down your reference that is not supposed to happen you have a short some where and until it is found the drive will not work right.
  17. #37
    Virginia
    15,783
    7561
    10667
    Not my area of expertise, but "hollow state" in general has been, Not necessarily a dead-short. Resistance path where none was meant to be, perhaps a capacitor that has perished, or a carbon-trail built-up of soot and biologicals or metal fines gone rogue. It may, in other words, be failed-component OBVIOUS, or it may be near-as-dammit invisible to an ordinary inspection.
    But yer right.
    It is "there somewhere", and detective work to FIND it must be put on the tasking list.
    Twiddling knobs ain't good enough to make it volunteer to undo itself.
    This stuff isn't "magical". Not as if it were a height-finder radar set, Lenkurt mux, or an FPTS rig.
    Fair SIMPLE, a thyratron DC drive, actually. But it CAN be tedious.
  18. #38
    Dec 2012
    81
    14
    Understood, any recommendations on a path through the system or just pick a wire and start following it? Also would pulling the module and running it help me isolate a particular area of the circuit?
    I'll be heading to training for a new job at the end of this week and will be out of contact for a couple months probably. Other side of the country and all. If i track it down before i leave i'll let you know otherwise it'll be a while!
  19. #39
    Mar 2016
    Louisiana
    483
    237
    87
    Disconnect wires on the scr side of the speed pot not on the field control side
  20. #40
    Dec 2012
    81
    14
    I disconnected the speed pot at point 36 and tried to run it. When I engaged it in fwd the C3J tube dimmed then the master contactor disconnected. Spindle turned briefly.
