tailstock depth system- DSG
M. Moore
Titanium
Jun 8, 2007
Vancouver Island, B.C. Canada
First post for the DSG guys (or anybody).
On my vintage DSG 13x42 lathe there is no tailstock depth micrometer. I would like to see how others have adapted their own machine to add a depth mic to the tailstock.
I was surprised when I got the lathe setup that on such a well built machine there was no depth mic on the tailstock, is there a reason they did not put one on? Very handy when drilling to a rough depth etc. Thoughts?
Michael
Not a DSG, but here ya go. The rod is a piece of keyed shafting, and there is a setscrew pin in the dial indicator body that rides in the key groove to keep the unit in its vertical position.
Actually that setup on the DSG pictured, is where I got the inspiration for mine. I have pics of that lathe in my tool porn file.
daryl bane, that is the nicest tailstock I have ever seen. Drool.
Ray I like your design very much.
I like the ideas so far. My biggest problem is that the tailstock quill fully retracts into the headstock in order to release the taper shanks. I am thinking that to rig up a mic of some sort I will have to fix that problem by extending the leadscrew end.
The tailstock on my machine is curvier than K Batt's but I don't think that will be a problem. I am definitely in favor of altering the machine to make improvements.
I also saw on Ray B's link a pic of someone who added a dial (?) mic to the handwheel on their lathe. That is very doable on mine as well. And seems like a fun job for the indexing head and the slotting attachment for the K&T......except I have to make a driver for the slotter and on and on it goes. Oh well one job at a time.
Keep em coming!
Michael
How does that work? If i read it right you only get the indicators travel maximum depth.
Personally i think the best one is marking on the drill itself. If the tailstock slips ur mic is out. But if that isnt an issue then its mint.
Daryl, I love it! Just like Monarch would have designed it. The coolest touch is the lock lever styled after the lock lever on the cross feed dial. thanks for showing it. How about some more shots of the lathe, and what you are still working on.
-Dave
I guess a grown up version of the Geo.H Thomas tail stock micrometer dial designed to fit the Myford hand wheel would do the deed quite nicely. Very similar in concept and layout to the one fitted to my Smart & Brown 1024 VSL, which works well. As does the dial on the saddle traverse.
Tail stock and saddle travel dials seem to have been a surprisingly late innovation. Seem to have been considered pretty remarkable things to design in prior to mid 1960's or there about's. Even on lathes of the very highest class. My P&W model B doesn't have either. Elliot / Cardiff seem to me to have been around the first to consider them as normal fitment on a shop lathe.
Clive
Just for the sake of very odd, is this tail stock dial on the Inch/Metric Monarch 10EE.
Unlike the other dials, the I and M scales are fixed together, the dial is geared so it rotates much slower then the hand wheel, and indicates total travel of the quill.
Large and nicely made, but, on the inch scale it reads in 1/64"!!!
...My biggest problem is that the tailstock quill fully retracts into the headstock in order to release the taper shanks.
Michael
I considered drilling and tapping two opposing holes on the face of the Tailstock Quill so that it would hold a .125" thick Dial Gauge Stop. The examples shown look so good that I will attempt to emulate the look.
I look forward to your solution.
Raymond
I have to agree, the machine work and the "art" of that first tailstock is amazing....Great work!
Here is my set-up. Mostly for gunsmithing. I used an inexpensive digital caliper that I cut and shaped. (You can simply buy a digital scale)
Hi,
This is the solution I currently use. I have a clamp that fits on the spindle and indicate from that. Some limitations to this setup though, the indicator only has 2" of travel, sometimes the clamp gets in the way.
Currently if the hole has to be more precise I hold a drill chuck in my QCTP and use the carriage to drill.
I recently purchased a new DRO for my lathe and I ordered it with a 3rd axis. I'm going to attach a low profile glass scale to the tail stock and I'll be able to use the 3rd axis of the DRO to measure hole depth. Hope to have it prototyped soon.
Dave
Yes it is.
My dad used to go to machinery surplus stores in Toronto when I was younger. I went with him when I was older, that's how I got into metal working. (When I was growing up didn't understand why my friends basements weren't filled with metal working stuff!)
One day he came home with a box of chucks made by Kawasaki. Must of been in the early 70s. I have them on my drill press, lathe, and mill, a really well made chuck.
Dave
I got one of those with a SB bench lathe 30yrs ago, got rid of the lathe and kept the chuck.
That drill chuck never slips, always ran true, and does not seem to wear out.
I have not been able to find another.
Maybe we should not tell how good they are!
Donie,
I was initially surprised that you could tell what type of chuck it was , simply by the small portion visible in the photo. They do have a distinctive knurl pattern don't they? I have to agree, they are a well made chuck, have to work hard to get the drill to slip.
In case anybody is interested in what they look like....
Dave
