Tailstock spindle repair?
Likes Likes:  0
Results 1 to 4 of 4
    Mar 2002
    dallas,tx
    2,454
    512
    436
    My EE tailstock spindle is a good rattlin'
    fit in its bore. What is the accepted method of rectifying this problem? And who (pro) can do this work? The spindle is also worn undersize also, to make matters worse. Scraping in the tailstock base is not a problem, I am just interested in the spindle and bore.
    Feb 2002
    Peralta, NM USA
    5,629
    47
    456
    I'd be tempted to bore the tailstock bore from the headstock, then chrome the spindle and center grind it to fit the new bore. If there's not a lot of eccentricity in the tailstock bore you might be able to simply lap it round again.
    But then I've never taken my tailstock apart, so I could be speaking from my nether orifice.
    Mar 2002
    dallas,tx
    2,454
    512
    436
    Russ, That is kinda the procedure I was thinking would work. There is a good hard
    chromer here in town and a good jig grinder.
    Although it would be nice just to send the
    damn thing to a guru and have it come back
    perfect, you know what I mean? Cheers Daryl
    Oct 2002
    Cincinnati, OH
    My model A tailstock is likely to need the same treatment.
    The ram does the shake rattle and roll when I extend it over 2.5" I have yet to measure the parts and find out where the wear really is though.
    Any insight on what exactly wears out this assembly???
