rke[pler
- Feb 19, 2002
- Peralta, NM USA
I occasionally find that a particular MT2 taper doesn't fit into my tailstock, and it's usually because the tang stops (the screws that are intended to stop a drill from spinning) interfere with the taper. Do others run into this or has mine been modified in some way so the taper is set back some?
