john_lynch
- Jul 16, 2002
- Santa Paula, CA USA
Hi All,
I've been monitoring this forum for a while (since I recently bought a 1952 10EE lathe), and I really appreciate the information available here. My machine is in pretty good condition, but it has one problem: on most parts (held in a collet, not between centers) it turns tapered. I've been investigating, and reading Connelly, and think that I need to make or find a test bar (12" long, 1-1/2" dia. like he says) with a Jarno taper to fit the spindle. I might try making one from a piece of precision ground bar, though I'm concerned about getting the taper accurate enough. Is anything like this available commercially, or should I have one made with a ground taper, or can I safely make one myself?
Any comments would be appreciated.
p.s. I'm also going to borrow a precision level to check the ways for twist, but nothing real obvious has emerged that's causing this problem.
John
John
