Brian@VersaMil
Stainless
- Mar 18, 2001
- Gaston, Oregon USA
My three tube later model 30 inch 10EE was not turning on after four years of not being used.
The 60 second timing relay is NOT working, allowing the green light to turn on and the lathe to
come to life. Bypassing the relay( applying 110 volts to the "C" terminal) the lathe works fine.
Did a search , and incredibly enough didn't find much info on this relay. Not many parts in it, but
these days I would wager almost all these parts aren't easy to obtain. Anyone replace their relay with a more modern timing relay?
I've been spoiled and use a large CNC lathe almost exclusively, but I have a 18 inch long casting that needs an ID thread in the bore.
CNC lathes just aren't set up to easily use a steady rest. After almost a ten year break of using my Monarchs to thread these, I did three of them last night.
I feel totally inept at threading on a manual lathe at this point. Only have a 3/8ths depth of thread that ends at a shoulder. So getting the threading tool disengaged, takes some real coordination. Used to do them on my 20 inch 10EE with electric leadscrew reverse and could FLY through them, although I had ZERO room. Bought the thirty
inch with this part in mind 15 years ago, and last night was the first time I used it for this job. My cnc lathe does these at 250 RPM and manually I felt I couldn't hardly go forty rpm without feeling apprehensive. Nice to have used my 30 inch though. At a 16TPI, I can only cut 7 threads, go too far my cutter crashes into the shoulder. Seven threads happens pretty quickly. No DRO so just using a dial indicator to determine depth. HAve to appreciate the abilities of people manually threading.
