zac_b
- Mar 9, 2013
- Brooklyn, NY
Bought about a year ago, life got in the way, finally biting the bullet on getting it running. Serial #48639, have a new manual from Monarch Sidney. It was reported running when removed from service (heh) with some speed control issues (heh).
The speed control pot feels crunchy and I'm waiting on a more electronically inclined friend to set up a test rig for the module diodes, so I'm testing operation with the module removed (which if I understand correctly should also take the iffy pot out of the equation).
Hooked up to mains 3-phase, the warmup timer seems to do what it should, the "control on" button engages PC, the c3j glows, and when I engage the ELSR carriage switch, three things happen:
1) the forward or reverse contactor engages (solidly as far as I can tell)
2) the QSD relay bounces and sparks
3) the c16's pulse as the QSD bounces
I haven't checked voltages yet, gonna wait and do that, along with diodes, under the eye of someone who's actually dug into HV circuits before.
Q1) The QSD seems to have a ton of free movement. It's (I think) the older style, with a big coil on its own phenolic plate. Found detailed pictures on other threads but don't recall seeing specs on contact distance or adjustment procedures. Any ideas (or any hey-dumbo-you-shoulda-looked-here's)?
Q2) Machine is hooked up through a 20a twist-lock, 60' of 4x10ga SO, and a 20a breaker - not going to be a permanent solution, but it seemed like it should allow for testing. Offhand, should I figure out a better feeder before moving ahead with troubleshooting?
Q3) Machine was listed as 3-phase and has 3-phase coolant pump, but the disconnect box had only 3 wire remnants - one per phase - and one was green. No ground/bond wire that I could discern. I wired each phase of my service and brought the ground wire to a case bolt ('cause that SO hookup is just a big extension cord, there's no conduit path to ground). This exact hookup is obviously temporary, but does either the original wiring scheme or my current hookup raise any red flags for basic testing? Should I check if it was re-wired for single phase and if so is anyone inclined to help me cheat on some diagram-reading?
Have a message out to the seller asking for more information and am hoping to catch Tim at Sidney tomorrow.
Down the road, pulling the carriage is the next mechanical task, but figuring out if I can make the drive work at all is the first order of business.
If anyone's still reading, any and all advice is welcome, and if not it's still been useful to get a record of where things stand. I'll be back either way :-)
And lastly, some pictures that I hope I've attached correctly!
