Hi all,
I have a '53 square dial lathe. The 1/4 turn "latch" that engages the spring loaded plate to retain the cover always gives me heart burn when re-installing the cover. Everything lines up and no gaps anywhere to indicate misalignment. At close inspection the plate does not slide easily on the screws and binds when the 1/4 turn dowel pin tries to ride up the bevel cut into the plate. There is no wear on the holes, plate, or screws. Has anyone modified this "latch" or made a new design?
