Gentlemen,
I recently got my EE lathe converted to a VFD drive. I changed to a 5hp motor and yaskawa vfd. WOW I am so glad I made the change. I ended up changing out the motor from the original reliance to a 5hp tefc inverter duty baldor, made and adaptor plate and used the original gearbox. The original controls had been removed some time ago and replaced with two ac drives, one for the field and one for the armature, it worked ok but this setup is awesome. If anyone would like model numbers or pictures let me know and I will try to post them. In closing, I would just like to say that if there are any out there that are on the fence about this change, I would say without a doubt, Go for it, you will be happy you did.
FredT
FredT
