lectrician1
Hot Rolled
- Mar 6, 2012
- Las Vegas
I have a 1955 WIAD
it came wired for 460 and I followed the sticky instructions in this forum to change the operating voltage
I did this conversion.
Everything seems to work
question - what about the CTs?
my schematic says the secondary of the CTs should have 80volts
I'm getting 24-27 volts
I don't know what it effects
one member suggested a shunt wire across the CT primary 20"long piece of #14awg wire.
His Modular schematic had a note about the shunt
I tried it. Secondary voltage dropped to about 10-12volts
I didn't notice any other change in the performance of the machine
I have plenty of torque at low speed of around 300rpm in high gear
any lower spindle speed and the motor cycles on and off
high speed 3250rpm
should i leave it alone or spend more time on this?
high speed 3250rpm
