Wanted: 10ee apron worm gear - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21
    Oct 2018
    Ohio
    85
    66
    6
    Doesn't look as worn as mine was. They crests of the gears were razor thin on one edge completely around. That gear is a quick change if it does fail, two pins on the rods > end bracket > and eight screws to drop the apron. Man, I feel good about this thing after having it apart and all back together making some chips.
  2. Likes jim314159 liked this post
  3. #22
    Apr 2011
    Wisconsin
    207
    46
    29
    Quote Originally Posted by rakort View Post
    I'm with labeeman.
    Run it. Backlash isn't really an issue with this worm gear.
    plus actually giving it lubrication with low service load I'm guessing it will last another 50 years.
  4. Likes Zap921 liked this post
  5. #23
    Oct 2018
    Ohio
    85
    66
    6
    Yep, that housing should have an external I.V. port for oil to be added at will. In looking at how mine looked, dry and full of grime/swarf, those gears don't get enough love from lubrication. I filled that sump up to the bottom of the feed rod through hole before closing it back up.
  6. #24
    Feb 2002
    Peralta, NM USA
    5,519
    43
    381
    Quote Originally Posted by Zap921 View Post
    There should be a oil line from the top sump in the apron leading to the worm gear. It's either plugged or the sump empties too fast for the line to get oil. You can see it in the first post in this thread:
    10EE Apron Overhaul
