Where does this indicator go?
Likes Likes:  0
Results 1 to 3 of 3
    Aug 2002
    Regina, Canada
    2,331
    5
    71
    Apparently the indicator in link fits 10EE but I can't see where. Anyone know?
    http://www3.sk.sympatico.ca/yawor/mong.jpg
    Bob
    Feb 2002
    Peralta, NM USA
    5,636
    48
    459
    Left side of the saddle/carriage there should be a little dovetail mount. The dovetail that you see on the right side of the mount in the image goes over that, the exposed end of the indicator then touches the micrometer stop bar mounted under the feed select knob in the headstock.
    Sep 2002
    Salinas, CA USA
    3,869
    197
    172
    Often the dovetail is missing, but it has
    a pair of dowel pins for alignment and a
    screw, so if you have three holes on the
    left end of the saddle then that is where
    the dovetail once fit.
    there are also bed stops available that
    work with the indicator, and there are
    other devices (e.g. a non-adjustable hard
    stop) that fit on the dovetail. The indicator fixture also comes in a variety
    that fits the right end of the saddle.
    My 1940 EE takes a different indicator and
    holder, even a slightly different dovetail.
