Shiseiji
- Sep 15, 2014
The accompanying document specifies 10 gauge wire for connecting to the main. So I diligently ordered some and a panel that can handle 10hp. Panel arrived so I started mounting it and placing the converter so it can be wired up. Surprise! When I opened the static phase converter everything is wired up with 14 gauge! Still shaking my head. Not convinced the wiring block will even take 10 gauge lugs. The wiring left on the back appears to be 14 gauge (eyeball calibration, accuracy not confirmed), the wiring in the panel where I checked the motor voltage also appears to be 14 gauge. Wiring diagram I have doesn't appear to have gauge specified. Comments?
