WTB Monarch Taper Clamp and Rod
WillWilly
Oct 4, 2018
USA Kentucky Lexington
I am looking for a Monarch CY16 Taper Clamp and Rod for my project. Mine is missing and appears the taper clamp was rarely used on my lathe.
Please PM me if you have one laying around. Who knows, I might have something you need in trade or just hard cash...
Thanks so much in advance
William
Lexington KY
You could look under the rear end (tail stock end) of T/A and see if you see two tapped holes - or maybe part of the front end of the "rod" that bolts on to those two tapped holes
Thumbnails might be helpful
Mine is broke off at that two bolt fitting and missing. Looks like I'm making a replacement. A good project!
I made the rod and clamp for mine. It wasn't a difficult project. Got some pix from people here which helped.
PDW
The previous owner of my 10EE made a bed clamp from steel.
I have often wondered if one could be 3D printed. The design would need to be different to have sufficient strength. Alternatively I think a simpler to fab design with a sacrificial link could be made out of other metal components.
Ryan
Ryan
I made my clamp from steel. IIRC I made the rod part first - it was missing - then dialed it parallel to the bed & measured to get the drop and offset from the rear ways. That told me where the hole had to go, the rest was a weldment tacked up in situ then fully welded. It works fine. Not that I use it a lot but it's nice to have it when you need it.
PDW
