WTB Monarch Taper Clamp and Rod
Likes Likes:  0
Results 1 to 9 of 9
    Oct 2018
    Kentucky
    230
    16
    50
    Cool WTB Monarch Taper Clamp and Rod
    I am looking for a Monarch CY16 Taper Clamp and Rod for my project. Mine is missing and appears the taper clamp was rarely used on my lathe.
    Please PM me if you have one laying around. Who knows, I might have something you need in trade or just hard cash...
    Thanks so much in advance
    William
    Lexington KY
    Oct 2018
    Kentucky
    230
    16
    50
    Shameless bump!
    Jul 2006
    Hillsboro, New Hampshire
    9,599
    2249
    6648
    You may have to fabricate them, I suspect it's a long-shot to find them at this point.
    Jul 2004
    Houston, TX USA
    31,028
    You could look under the rear end (tail stock end) of T/A and see if you see two tapped holes - or maybe part of the front end of the "rod" that bolts on to those two tapped holes
    Thumbnails might be helpful
    Mar 2017
    141
    29
    63
    Vettebob made them for the 10ee although he hasn't posted in a couple of years
    10EE Taper attachment clamps and rods
    The rod is little more than threaded rod, but the clamp is tricky.
    You don't have to clamp the rod to the bed. You could clamp it to anything that will hold it still.
    Oct 2018
    Kentucky
    230
    16
    50
    Quote Originally Posted by johnoder View Post
    Mine is broke off at that two bolt fitting and missing. Looks like I'm making a replacement. A good project!
    Jul 2006
    Australia (Hobart)
    3,778
    587
    2880
    Quote Originally Posted by WillWilly View Post
    I made the rod and clamp for mine. It wasn't a difficult project. Got some pix from people here which helped.
    PDW
    Dec 2012
    Cocoa, FL
    141
    5
    18
    Quote Originally Posted by PDW View Post
    PDW
    The previous owner of my 10EE made a bed clamp from steel.
    I have often wondered if one could be 3D printed. The design would need to be different to have sufficient strength. Alternatively I think a simpler to fab design with a sacrificial link could be made out of other metal components.
    Ryan
    Jul 2006
    Australia (Hobart)
    3,778
    587
    2880
    Quote Originally Posted by reidry View Post
    Ryan
    I made my clamp from steel. IIRC I made the rod part first - it was missing - then dialed it parallel to the bed & measured to get the drop and offset from the rear ways. That told me where the hole had to go, the rest was a weldment tacked up in situ then fully welded. It works fine. Not that I use it a lot but it's nice to have it when you need it.
    PDW
