3 ball valves on a single stem - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #21
    Oct 2014
    Maine
    1,092
    164
    516
    Quote Originally Posted by EmanuelGoldstein View Post
    Or line them up in a row, replace the handles with stock gears from Boston, and run a rack across all three to actuate them simultaneously.
    If I can get both CW and CCW opening valves, I could do away with the rack and just mesh the gears directly.
    I heard back from Swagelock and they do a geared 2- or 3-valve to a single handle in 1/4" tube (model GSM), but I'm using 3/8 pipe or 1/2 tube. I'll have to run the flow calcs and see how bad it would be to neck it down.
  2. #22
    Oct 2014
    Maine
    1,092
    164
    516
    Quote Originally Posted by atomarc View Post
    There isn't a common line that feeds the 3 'pipes' that could be shut off? Probably not. Ganging the 3 handles together with linkage isn't a option? Probably not.
    Sadly, there need to be multiple air lines coming in. Unless there is a major redesign and we switch to much more expensive components.
  3. #23
    Mar 2009
    Eureka, CA
    4,036
    872
    1502
    It's nice to see the OP get back and respond to all the various suggestions..even Stu's silly one. A sub-sea environment certainly would complicate things I suppose. I sure would investigate pneumatic valves further though.
    Stuart
  4. #24
    Dec 2012
    MN
    115
    36
    Daniel:
    You might look at these 1/2" butterfly valves. I would think the stem could be extended downward to couple to additional valves.
    B5101 Series Butterfly Valve with Pull Handle Clamp End | Dixon Valve US
    Or perhaps other butterfly valve manufacturers could supply these.
    Regards,
    DB
  5. #25
    Sep 2010
    Oklahoma City, OK
    5,044
    907
    2117
    Quote Originally Posted by DanielG View Post
    A double stem valve would be ideal. They wouldn't even require a linkage. Attach the back stem of valve 1 to the front stem of valve 2 with a rigid coupling. Back of valve 2 to front of valve 3. Unfortunately, as you point out, I've never seen a double stem valve.
    Probably wouldn't be a hard modification to a trunnion mounted ball valve since the body is already machined for a cap on the bottom. Granted, I don't think I've see a trunnion valve smaller than 12", much smaller than that and they just float.
  6. #26
    Dec 2003
    Washington
    4,903
    2420
    4488
    I did something similar with three rotary disconnects with one handle, 90 deg operation. Used laser burned linkage from 10GU stainless with short shoulder bolts. Hundreds of these in use but none under water. A short stroke cylinder operator would be easy to rig. I can snap a photo and post if you like.
  7. Likes Scottl, Limy Sami liked this post
  8. #27
    Mar 2006
    jacksonville,fl.
    1,291
    1167
    436
    Depending on the pressures involved,if you could use pinch valves they have an advantage in that there is no mechanical linkage involved so no corrosion or linkage wear to worry about.You could even use a liquid to actuate them if that would offer any advantage.They are available in plastic.
  9. #28
    Jun 2013
    Northern Il
    1,457
    750
    1345
    Groco makes a stacked three way fuel.
    GROCO FV-Series Six-Port Fuel Valve | West Marine
    Not sure if this is even close for your application but we use these on boats as a tank selector valves. You can switch between two tanks for an engine and never have issues of messing up with individual valves.
    These are cast marine bronze.
  10. #29
    Mar 2006
    jacksonville,fl.
    1,291
    1167
    436
    In case you are not familiar with pinch valves,this is one type. https://www.redvalve.com/uploads/Ext...ves/Type_A.pdf
    I have some in 1/2" and think they are made in smaller sizes.
  11. #30
    Alpine california usa
    108
    131
    27
    Easiest way is to use these
    Belimo B212B+TR24-SR-T US Motorized ball valves in any voltage
  12. #31
    Mar 2006
    jacksonville,fl.
    1,291
    1167
    436
    Drroaster, did you miss the part about being dunked underwater?Possibly saltwater(he said undersea).
    Personally I'm a big fan of the KISS principal.
  13. #32
    108
    131
    27
    No I did not my bad thank you omit my last post haha
  14. #33
    Apr 2002
    Syracuse, NY USA
    9,783
    19
    599
    I have seen two large gate valves side by side tied together with chain. But that doesnt help here. It seems that a simple tie bar would work if the operator was gripping the bar
  15. #34
    Nov 2013
    Eastern Massachusetts, USA
    5,749
    5321
    5438
    Quote Originally Posted by surplusjohn View Post
    Exactly. Think of something like the throttles on a jet. In this case however the handle would be solid so no valve could be moved independently. All it requires is that the links be "L" shaped so the handle doesn't hit the tubes.
  16. #35
    Sep 2002
    People's Republic
    4,603
    450
    2779
    weld the capital letter 'E' about 3-4 inches tall
    Weld it to the ends of the handles at a right angle to the handles such that when in the 'open' position it does not interfere with the valves or pipe.
  17. #36
    Nov 2013
    5,749
    5321
    5438
    Since there doesn't appear to be an off the shelf solution I'm curious why a simple linkage to gang the valves isn't an option?
    What gustafson suggested is essentially the same as what I suggested except that instead of welding I suggested a fabricated linkage that works the same way. The levers don't need to be bent 90 degrees (an L shape). Instead they could be straight with a threaded rod and spacers to connect. Where they would vary from the standard handle is that the opening that attaches to the valve stem would be offset 45 degrees from normal. Normally a ball valve handle is perpendicular when closed and parallel when opened. These would be at 45 degrees one way when closed and 45 degrees the other way when open.
    Making the levers would be a simple job for a shop with a water jet.
    If there is room, one lever could be extra long so it is easier to grab and manipulate.
  18. #37
    Dec 2003
    Washington
    4,903
    2420
    4488
    Here is what we do for 3 ganged motor disconnects adjacent to one another . . .
  19. Likes Mud, atomarc, Comatose, gustafson, Limy Sami and 3 others liked this post
