Lower-cost alternative to Automation Direct PLC
Results 1 to 15 of 15
    Oct 2010
    Portland, OR
    761
    148
    259
    Default Lower-cost alternative to Automation Direct PLC
    I'm helping a customer implement mask sewing/processing and came up with a method to "weld" the polypropolene together using cheap soldering irons. I can "semi-automate" the process with just a foot valve and air cylinder but would like to take it a step further to at least control the timing. This would change the foot valve to a switch, activate a solenoid valve for 1-2 seconds to extend the cylinder, retract it, then shine a light after about 2 seconds to tell the operator they can pull the part (keep light on for a few seconds, then turn it off). About as "wash/rinse/repeat" as you can get.
    Since it's for mask production, at this point it's only going on for maybe 7-8 weeks. Further automation/closed-loop control isn't likely justifiable (cylinder prox swtiches, temp controls, etc.). My knowledge is best suited to AD D05 series PLC which you can buy for about $90-100 but it's much more capable that what's needed.
    Here's the minimum specs:
    Ideally l20 VAC, 12 or 24 VDC power.
    2 outputs. Could use another one just to indicate the power is on.
    1 input for the cycle switch.
    Cheap/free ladder logic software (that's the only control language I know, probably take to long to learn a new language unless I can find someone local to program it).
    I did find a cheap "Module FX1N-14MT-2" PLC (open board, no case) on eBay, looks like it would work. Uses Misubishi GX Developer Or GX Works2 software that I could likely learn pretty quick.
    Just wondering if anyone has any suggestions. I investigated the PI a year ago for another application, main concern is learning C++ or whatever the language was. Do you think there's someone who'd be willing to write a program for it?
    We'll likely be building at least 10 of these, up to 15-20 depending on final cycle time & demand. Not "super urgent", if I can't find anything cheap, quick to buy and easy to implement, I'll keep it with just a foot valve.
    The Dude
    May 2018
    New York
    117
    94
    75
    check out smart relays, I'v used in the past IDEC FL1F for small projects.
  3. Likes thomj liked this post
    Jun 2018
    Wisconsin
    58
    33
    Get a Click PLC and be done with it. You're already familiar with AD's software and finding anything cheaper than $70 on ebay will take more effort in research of the product and its software to figure out if it will work. How much is your time worth? If it takes 45 minutes for one ebay listing it might be worth it. If you buy that one listing off of ebay, can you find 10-20 more of them for the same price or will you need to do 45 min more research per unit and end up with every unit being a Frankenstien's monster? If the customer really wants to complain over the choice of a cheap PLC, they can't afford the project.
  5. Likes greggv, 3t3d liked this post
  6. #4
    Jan 2007
    Flushing/Flint, Michigan
    8,665
    467
    7111
    Hard relays? No computer of fancy stuff.
    Bob
  7. #5
    Oct 2010
    Oregon
    5,300
    4749
    1945
    Buy one PLC with enough I/O ports and timer resources and have it run all 10 or 20 assembly stations.
    Build your own three- or four-step ladder with relays. Gotta say that a (new) Omron time delay relay costs a pretty good fraction of a Click PLC, though.
  8. Likes matt_isserstedt liked this post
  9. #6
    Mar 2009
    Eureka, CA
    3,910
    814
    1414
    About the only thing I've seen cheaper than the small PLC's from Automation Direct are cocktail napkins from Trader Joe's. What's your budget for this project...$20.00 dollars?
    Stuart
  10. Likes sfriedberg, greggv liked this post
  11. #7
    Oct 2010
    Oregon
    5,300
    4749
    1945
    Yeah, my initial reaction to the thread title was "Automation Direct is the low-cost option." But maybe he doesn't need to buy a separate PLC for every station.
  12. Likes BugRobotics, matt_isserstedt liked this post
  13. #8
    May 2010
    Indiana
    206
    34
    Look at Maple. They make a reasonable plc.touchscreen in one unit that takes various i/o modules
  14. #9
    Oct 2014
    Maine
    1,037
    148
    493
    It doesn't get much cheaper than a click PLC, and it will be there in two days.
    I've also heard good things about Velocio. they start at $50, but you'll need a separate power supply, and if you already have 24V for the pneumatics, it's not cheaper than a click.
  15. #10
    Apr 2013
    18
    7
    I have used Velocio PLC's for a couple of very similar applications. They are inexpensive and - in my experience - reliable. Ladder writing software is free and simple to use and their support is very responsive.
  16. #11
    Oct 2013
    New Jersey
    1,176
    1002
    AD supports the 305 and 405 series for at least 30 years too. 205s are still current after 25 years. Stop trying to do cheap and focus on making the process better and make money.
  17. #12
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,150
    450
    1077
    Quote Originally Posted by sfriedberg View Post
    That's my decision right there. If a single timer is required then you might as well go the PLC route.
    There are old school mechanical leakdown timing relays but why bother?
  18. #13
    Sep 2019
    Kansas
    9
    Great idea, it will spare us some bucks! I will try it and hopefully it will work good.
  19. #14
    Oct 2013
    New Jersey
    1,176
    1002
    It'll work, right up to the point where the customer says "This is great! Now that I see how it works we just need to add...". You are supposed to be helping the customer not hindering him.
  20. #15
    Feb 2010
    IN, USA
    257
    7
    270
    Quote Originally Posted by garyhlucas View Post
    It's called a "change of scope", meaning you buy another dirt cheap PLC and double the price of the machine.
